02/03 and 04/05 Subaru WRX init connectors now available
Postby cboles » Mon Apr 24, 2006 5:07 pm
I now have init connectors available on http://tactrix.com for the 2002/2003 MY and 2004/2005 MY WRXs. Hopefully no one will have to jam paperclips and the like into the connector sockets anymore while reflashing :shock: ...
2004/2005
Postby TedS » Sat May 06, 2006 4:38 pm
Is this the only connector we need to hookup?
Is this the only plug that has this shape right there under the dash? I don't see any others.. ?
TedS
Postby cboles » Sat May 06, 2006 10:03 pm
You also need to hookup the green test mode connectors while reflashing or reading the ECU.
Postby TedS » Sun May 07, 2006 12:58 pm
Well I was impatient and rather than be smart and wait for a reply I stuck some paperclips into the 4-prong connector between the top and bottom pins, and viola I was able to program my ECU.
I noticed there's a single prong male/female connector set right there too.. Are those the 'green test connector'? Why am I supposed to connect those?
TedS
Postby cboles » Sun May 07, 2006 1:03 pm
What model car do you have? Are the connectors you mention green?
Postby TedS » Sun May 07, 2006 2:33 pm
Oh! I have an 04 WRX.. Probably the reason?
TedS
Non DBW?
Postby scoobydk » Thu Aug 31, 2006 1:52 am
Will any of this work with my non DBW European 04 STI ?
What cable do I need?
scoobydk
Postby cboles » Thu Aug 31, 2006 2:08 am
Get the cable which says "for WRX" - it includes both types of connectors.
Postby scoobydk » Thu Aug 31, 2006 2:11 am
scoobydk
Postby cboles » Thu Aug 31, 2006 2:26 am
the same!
Postby scoobydk » Thu Aug 31, 2006 2:49 am
thank you - Will try, even though it says for drive-by-wire wrx :)
scoobydk
Re: 02/03 and 04/05 Subaru WRX init connectors now available
Postby stiboi » Sun Jul 04, 2010 11:49 pm
i have a 2002 model wrx sti im new to all this i bought the trac trixs open port 2.0 and the 2002 wrx jumper i connected the two green connectors but my car doesnt have a 2pin white plug it has a four pin plug so i test write it. it says inferface error so what can i do with the jumper how would i do it please help me
stiboi
Users browsing this forum: Google [Bot] and 43 guests
