ici la france hello
ici la france hello
Postby babcool » Sat Apr 10, 2010 12:06 pm
hello y m french h have a question for the forum is it taxtrix 2.0 is ok for sub sti edm 04?
switch green ,fan test ignition on and read open 1 42 2595 kuikli and no reponssssss shit ... pc ok pilot ok? wath else haa...... it my sti and never reflash can you help me ? maybee hold open ecu exe???? sory for my english cyril
babcool
Re: ici la france hello
Postby radsdau » Sun Apr 11, 2010 4:37 pm
Yes, Tactrix Open Port 2 is ok for STi EDM 04. You will have trouble if:
* you select the wrong hookup method to connect to your car
* your car has a second set of test connectors that aren't connected, but I don't think this applies to your car. When you say 'Fan Test', do you mean that the fans cycle when the green test connectors are joined? If so, then it should be ok.
* your ECU has been flashed by a third party such as EcuTeK or Cobb
I presume "open 1 42 2595 kuikli and no reponssssss" means you are using ECU Flash 1.42? That is the latest stable release, and should be fine.
Postby babcool » Sun Apr 11, 2010 10:47 pm
Thank you for the reponsse, I make quite OK (taken test, conect flash) can etre not rather fast between etapes j have pass my week end on the site open ecu had there that I ca has to work after y put on-line my positive resultats on the site
babcool
Postby Frenzy » Tue Apr 13, 2010 9:37 am
Are you using something like google translate ? :lol:
Si tu as besoin d'aide , n'hésites pas à m'envoyer un message privé.
Frenzy
Postby babcool » Tue Apr 13, 2010 11:14 pm
ok frenzy merci
babcool
