1.3U connectivity Problem
Postby Hotwire » Tue Jan 05, 2010 6:56 pm
I'm hoping someone can shed some light on this for me:
I have a Tactrix 1.3U cable - Cable connects fine, can use RomRaider and Learning View without issue.
However I put the car into diagnostic mode using the green connectors - get fans cycling and CEL flashing, however when I go to read the rom with ECUFlash I get nothing! ECUFlash just states "closing interface"
I have previously both read and written with a 1.3M cable no worries. Made sure I could read the ROM with ECUFlash after the flash too - worked fine. However, I attached the 1.3U cable not even 24 hours later and I can't read the ROM
Only thing I can think of is that when in test mode, my battery volts are sitting at 11.9V with the fans cycling. Is there a lockout in the 1.3U cable if volts are below 12.0V?
Any help is appreciated as very confused
Hotwire
Re: 1.3U connectivity Problem
Postby radsdau » Tue Jan 05, 2010 11:12 pm
There is a lockout for under and over voltage on HC16-based ECUs, but I thought it let you know if that was a problem. 11.9V might be cutting it pretty fine if the ECU is that type though.
If it's a DBW ECU, there shouldn't be those issues.
Otherwise, all I can think of is updating drivers. Sorry I can't be of more help.
Postby Hotwire » Wed Jan 06, 2010 4:15 am
Sorry should have clarified.
This is on a 2004 ADM Subaru Liberty (Legacy) GT with drive by wire 32 bit ECU.
I have removed and reinstalled the drivers a couple of times now. Maybe worth trying ECU Flash 1.41 for the 1.3U cable?
Hotwire
Postby Hotwire » Wed Jan 06, 2010 5:08 am
Just to add, took a log of trying to connect to the vehicle:
[23:29:51.187] EcuFlash Version 1.42.2595</p>
[23:29:51.187] OS Version Windows XP</p>
[23:29:51.187] Qt Version 4.5.0</p>
[23:29:51.187] 56 memory models read.</p>
[23:29:51.218] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata</p>
[23:29:54.796] 343 ROM metadata models scanned.</p>
[23:29:54.796] checksum module "subarudbw" loaded.</p>
[23:29:54.796] checksum module "mitsucan" loaded.</p>
[23:29:54.796] flashing tool "wrx02" loaded.</p>
[23:29:54.796] flashing tool "wrx04" loaded.</p>
[23:29:54.796] flashing tool "sti04" loaded.</p>
[23:29:54.796] flashing tool "sti05" loaded.</p>
[23:29:54.796] flashing tool "mitsukernel" loaded.</p>
[23:29:54.796] flashing tool "mitsukernelocp" loaded.</p>
[23:29:54.796] flashing tool "mitsubootloader" loaded.</p>
[23:29:54.796] flashing tool "shbootmode" loaded.</p>
[23:29:54.890] flashing tool "shaudmode" loaded.</p>
[23:29:54.890] flashing tool "subarucan" loaded.</p>
[23:29:54.890] flashing tool "mitsucan" loaded.</p>
[23:30:32.171] Using interface OpenPort 1.3 Universal TX28eldqdc66b6c599a84065d673e5eafe751d2d5391b7d3</p>
[23:30:32.171] interface close</p>
[23:30:32.171] unable to connect to vehicle interface.</p>
[23:30:48.843] Using interface OpenPort 1.3 Universal TX28eldqdc66b6c599a84065d673e5eafe751d2d5391b7d3</p>
[23:30:48.843] interface close</p>
[23:30:48.859] unable to connect to vehicle interface.</p>
[23:30:48.859] interface close</p>
So any help would be great!
Hotwire
