EvoScan HighSpeed Mitsubishi/Subaru USB Datalogging Cable
Postby Dstretch33 » Tue Sep 02, 2008 3:07 pm
Hi, I was looking for the older tactrix version 1 cable. I have been told that it is no longer available from tactrix or tuner tools.com. They will only be selling the version 2 cable that cost 170 shipped. So I have found another option for a data logging cable with the evoscan unit sold here:
http://www.limitless.co.nz/cables/
It is 100 bucks and supports 1.3U or 1.3B which will work with my 04 sti. I want to reflash this XPT map onto my car:
http://www.plasmatize.com/xptstore/index.php?main_page=product_info&cPath=6_5_10&products_id=24&zenid=1918248d92953d354bc7ea450a859d6f
Does anyone see any reason this will not work? I already have a freind that is using ecuflash on his evo. So we have the software required. Just looking to get feed back on this setup.
My current modifications are:
-Invidia catless dp
-Hks Hipower
-K&N sri
Thanks in advance.
Dstretch33
Re: EvoScan HighSpeed Mitsubishi/Subaru USB Datalogging Cabl
Postby Jon [in CT] » Tue Sep 02, 2008 4:16 pm
Dstretch33 wrote:Hi, I was looking for the older tactrix version 1 cable. I have been told that it is no longer available from tactrix or tuner tools.com. They will only be selling the version 2 cable that cost 170 shipped. So I have found another option for a data logging cable with the evoscan unit sold here:
-Invidia catless dp
-Hks Hipower
-K&N sri
Thanks in advance.
Your friend's Mitsubishi cable will work with your 2004 STI. If you buy the limitless cable you will have to run EcuFlash 1.29
or earlier. Newer releases won't work with the limitless cable.
Postby Dstretch33 » Tue Sep 02, 2008 5:45 pm
So the 1.3m for Mitsubishi evo8 is the same 1.3m for Subaru Sti??
http://openecu.org/index.php?title=EcuFlash:VehicleSupport
STi 2004-2007 1.2 1.3S 1.3M 1.3U 2.0
Evo 8 1.3M 1.3U 2.0
Dstretch33
