2005 uk wrx cant read ecu
Postby young un » Mon Jun 23, 2008 12:37 pm
can any one please help i cant seem to get my pc to read from my ecu ive tried 2 different ecu's one was a standard ecu and the other was a prodrive ecu
[20:58:05.728] flashing tool "shbootmode" loaded.
[20:58:17.463] using interface open port 1.3
subaru
TX48H9ff129574d51c67650771f5205275d07e3c9f8621a7
[20:58:22.404] denso02_bootloader_cmd_start
[20:58:23.326] denso02_bootloader_cmd_start
[20:58:24.529] denso02_bootloader_cmd_start
[20:58:25.748] denso02_bootloader_cmd_start
[20:58:26.951] denso02_bootloader_cmd_start
[20:58:27.357] kernel get version
[20:58:27.685] interface close
[20:58:27.701] interface close
any help would be apreciated
young un
Postby radsdau » Mon Jun 23, 2008 3:12 pm
Most likely causes:
1. Wrong vehicle type (different connection method)
2. Green test mode connectors not connected (NOTE: there may be 2). Fans should cycle in test mode.
3. Not clicking 'Ok' quickly enough after turning the key on
Check those first then let us know how you went.
Postby young un » Tue Jun 24, 2008 7:54 am
i have connected the green connectors and the reflash plug for the 2005 wrx, the fans on the car come on then go off continuously.
i have tried turning the ignition on beofre and after clicking ok but it still does not connect.
The tactrix lead works perfectly fine with romraider so i dont think there is anything wrong with the lead, im going to try unistalling the software and reinstalling it to see if that sorts it out the only other thing is im using windows vista dont know if that has been causing any problems with the software.
Ive tried using the other vehicle types on the sofware but they dont work the one i should be using is 2001+ non usdm/ wrx/sti
young un
Postby young un » Thu Jun 26, 2008 7:20 am
tried my laptop and lead on a 2003 uk sti last night and it worked i then tried it on a 2004 uk sti and it would not work, is it possible that ecutek can lock us completley out so we cant even read the ecu
young un
Postby blue.taxi » Thu Jun 26, 2008 7:43 pm
if there is hv or hv been a ECUtek in the ECU, sorry to said that u cannot rear or over write.
blue.taxi
Postby radsdau » Mon Jun 30, 2008 2:59 pm
radsdau wrote:Most likely causes:
Oh yeah, I forgot:
4. ECU locked by someone else (EcuTek, Cobb, etc)
The only way to get around #4 is to get ET to unlock it for you (from what I've heard this never actually works, and you still can't read the ECU), or get someone else to restore your ECU- the ET license will be lost. There are a couple of places this can be done (search this forum).
Postby young un » Tue Jul 01, 2008 7:59 am
tried the original ecu off the car again which does not have the ppp pack on it and it worked only thing is now ive got to get the keys reprogrammed to the ecu
young un
