Mitsubishi Galant ECU Read Failure
Postby remarque » Fri Apr 04, 2008 9:29 pm
Here my problem I have a 1999 Mitsubishi Galant I tried to read the ECU but a window pops up saying a error has occured heres the log:
TX37w3rGc667b4d9d0b99037197a4a50e4ef64775912bc6f
[16:39:27.078] sending init sequence 1 (0001)
[16:39:30.296] sending init sequence 1 (0003)
[16:39:33.515] sending init sequence 1 (FFFF)
[16:39:36.750] sending init sequence 1 (F0F0)
[16:39:39.500] no response to any known code
[16:39:39.500] interface close
[16:39:39.515] interface close
I also have a 2001 ECU that want use since my 99 ECU is not flashable. I installed it on my car and tried to read the ECU put another window popped up saying a errror has occured. Heres the log:
[13:30:17.265] sending init sequence 1 (0001)
[13:30:20.500] sending init sequence 1 (0003)
[13:30:21.546] got 0x05 response
[13:30:21.546] sending init sequence 2
[13:30:21.562] got 0x1B response
[13:30:21.562] sending init sequence 3
[13:30:21.984] entering bootloader
[13:30:21.984] sending kernel size (0)
[13:30:22.031] sending kernel load address (0xFFFF6000)
[13:30:22.062] uploading kernel
[13:30:22.062] verifying kernel checksum response
[13:30:22.078] kernel valid
[13:30:22.078] sending init sequence 2
[13:30:24.109] interface close
[13:30:24.125] interface close
I can here the relays firing, but it just want read. Can some help me.
remarque
Postby spdracr » Tue Apr 22, 2008 10:09 pm
anything on this ?? i cant read mine either
spdracr
Re: Mitsubishi Galant ECU Read Failure
Postby vishel » Thu May 22, 2008 5:34 pm
remarque wrote:Here my problem I have a 1999 Mitsubishi Galant I tried to read the ECU but a window pops up saying a error has occured heres the log:
Bump
I would like to know if theres a way around this too. Trying to flash my '99 JDM Mitsubishi Diamante and get the same message.
vishel
Users browsing this forum: No registered users and 38 guests
