Help needed for OpenPort 1.2
Postby ECUboy » Sat Jan 21, 2006 11:42 pm
Hi,
I have got the OpenPort 1.2 and it does work fine with Tari logging software. However, I couldn't get it work with DeltaDash, is there any configuration require?
I need it cos wants to run the run dyno.
Your help is very much appreciated.
Thanks.
ECUboy
Postby ECUboy » Sun Jan 29, 2006 8:19 pm
Any expert advise? Or is there a road dyno software to recommend using OpenPort 1.2?
ECUboy
Postby Freon » Sun Jan 29, 2006 9:33 pm
Post a log with time, RPM, and speed, maybe manifold pressure as well, but nothing else, full throttle pull all the way through a gear (2nd or 3rd would be ok). Post several under the same conditions if possible.
Postby ECUboy » Mon Jan 30, 2006 9:50 pm
Sorry, I mean DeltaDash can't detect the OpenPort1.2 was connected, hence can't do any dyno. Any advise how to get it work?
ECUboy
Postby calvinc » Mon Jan 30, 2006 10:47 pm
very silly question but have you selected the right com port? if you used dd with the old cable it will be looking for the wrong com port.
Postby cboles » Mon Jan 30, 2006 10:47 pm
The Openport should appear as a seril port on you computer. You can't pick that port from a list of serial ports in DeltaDash? I'm of course assuming that you have a DeltaDash license... otherwise you won't be able to do anything at all.
Users browsing this forum: Google [Bot] and 34 guests
