Wire came loose...
Wire came loose...
Postby tcarretti » Fri Dec 29, 2006 4:08 pm
I'm sure that this has been addressed before but all the posts that I have seen simply say that Colby took care of it....
SO....
Was downloading the ROM from the ECU. When I was done and disconnected the cable the wire leading to the white connector came loose from the red crimp connector.
Can I simply recrimp with a new connector or is there something special about the connector that was used?
thanks, it might be a stupid question, but better safe than sorry.
tony
tcarretti
Postby BarryC » Sat Dec 30, 2006 2:19 am
Its just a standard connector suppose its only there so you can remove the flashing socket on the lead for convenience,
BarryC
Postby Evo4Mad » Sat Dec 30, 2006 5:04 am
yeah you could just re-join it by fitting a new standard plug, or just cut the red plugs off and wire them together permanantly, thats what I did.
Postby tcarretti » Sat Dec 30, 2006 7:18 am
Thanks guys!
I was pretty sure that was the case I just wanted to make sure.
tcarretti
Postby cboles » Wed Jan 10, 2007 4:13 pm
Yes - I really debated putting that connector in or not. I just figure for people logging all of the time, or using the cable for Subarus, they would want to remove the reflash connector.
