Which cable for JDM 2003 LGT Spec-B AT??
Postby RocketmanTT » Sun Dec 03, 2006 10:24 am
Hello All,
I'm new to the forum and Subaru scene. I've put a deposit on a 2003 JDM LGT 2.0 Spec-B (4th generation) and would like to be able to do my own performance tuning.
I've had a look at some of the material and Tactrix has cables, but I'm not sure which one I shoud get. Can someone point me in the right direction.
Also, does anyone have stock and modified ECU images for this model?
Lastly, can images be viewed and modified offline and if so, what utility should I use.
Thanks much.
RocketmanTT
Postby RocketmanTT » Tue Dec 05, 2006 1:04 pm
Wow, I can't believe so many folks viewed this and not a single reply.
Surely someone must have the answer.
RocketmanTT
Postby Rotawerx » Tue Dec 05, 2006 3:10 pm
I am guessing the Subaru one will do it, but Im just assuming. Buy it and try it ;)
Rotawerx
Postby RocketmanTT » Tue Dec 05, 2006 4:37 pm
Thanks much...I'll probably give Tactrix a call.
RocketmanTT
Postby Jon [in CT] » Tue Dec 05, 2006 4:47 pm
Any of the Tactrix cables currently offered for sale should work. The only question is whether you need a reflash connector. If you opt for "OpenPort for Subaru WRX and Drive-by-wire vehicles" then you should be able to read/write all 2002+ turbo and DBW Subaru ECUs.
Postby RocketmanTT » Wed Dec 06, 2006 4:06 am
Jon [in CT] wrote:Any of the Tactrix cables currently offered for sale should work. The only question is whether you need a reflash connector. If you opt for "OpenPort for Subaru WRX and Drive-by-wire vehicles" then you should be able to read/write all 2002+ turbo and DBW Subaru ECUs.
You're right, a friend of mine told me that the OpenPort 1.3U cable is the one I need and those come with reflash connectors too. 8)
RocketmanTT
