Flash Jumper
Flash Jumper
Postby drfranky » Wed Nov 08, 2006 1:29 pm
Guys.
I'm in the process of rewiring my car ( swap ).
Here is the situation,
I can Data log no problem.
I can put the Car in diagnostic mode ( grounding B134-14 ).
However I'm not able to read/write. This is probably because I'm not using any flash block connector.
Can you please give the the 2 pins it connects in the ECU for a WRX 2002+ ?
Thanks.
Swap Info:
STI Ver 7 in Legacy GT 99.
drfranky
Postby Freon » Wed Nov 08, 2006 4:57 pm
Search for flash block or flashblock. You can also see a picture of what the flash block connector is doing by looking at the Tactrix site.
I think on the 2002 it is just shorting the white connector. Only two pins, and you just connect them. A piece of 16G or 18G wire with leaded ends can just be shoved into the connector, just make sure it is secure before you start flashing. Or just buy a connector for a few bucks.
Postby drfranky » Wed Nov 08, 2006 9:13 pm
I don't have this connector.. It's a swap with custom wiring... that's why I want to know which pin on the ECU this Flash Block Connector interacts with. My best guest is that I need to connect 2 pins together.. I just want to know which one.
drfranky
Postby drfranky » Thu Nov 09, 2006 7:18 am
Flash Block connects: B134-10 to B40-6 for WRX 2002-03 type of car.
drfranky
Postby wrx-blue-mica » Fri Nov 10, 2006 10:43 am
My WRX Aussie version 2002 has to use 4 pin flash jumper that suppose to be for 2003.
wrx-blue-mica
Users browsing this forum: No registered users and 54 guests
