cold problems
cold problems
Postby m3n0ch3 » Mon Oct 23, 2006 1:51 pm
Hi guys,
today I had a weird problem. After a cold night with the tactrix cable in the car, I had problems connecting it to the laptop. I had USB port voltage power surge....
It took about 10 minutes to warm it up and then I was able to use it...
Have you guys seen this with a tactrix cable?
Phil
m3n0ch3
Postby m3n0ch3 » Tue Oct 24, 2006 3:49 am
Tuns out some contact in the cable got flaky with the cold???
if I push back the cable into the obd casing, everything works :-(
isn't there a holder or a block inside the connector to prevent the cable from being pulled?
m3n0ch3
Postby gethin » Tue Oct 24, 2006 10:49 am
Could be a "cold" solder joint affected by temp.
gethin
Users browsing this forum: No registered users and 49 guests
