USM2 compatible?
USM2 compatible?
Postby bluescoobywagon » Mon Sep 25, 2006 10:42 am
I was wondering if it's possible to use the part here http://www.pic-tools.com/usb_mod_ums2.htm to modify my existing ODB-2 cable. This appears to mirror most of the openport 1.2 schematic and would only require the voltage comparator, 12v regulator, a few transistors and a few resistors and capacitors. It would be easier to solder seeing as most of the little bits are pre-done and everything else could be DIP and TO-92. Plus I have most of the parts laying around. Thoughts?
bluescoobywagon
Postby cboles » Fri Sep 29, 2006 11:53 am
yes, it could be done. i use similar eval boards when prototyping my designs.
Postby bluescoobywagon » Fri Sep 29, 2006 7:31 pm
After pricing out all the parts, I decided it wasn't worth it to save $35 by going through all the hassle for something that would work, but would take hours and hours of my time. Instead, I just ordered the cable from Tactrix. I'll keep my old OBD-2 cable and software in case I need them for other vehicles.
bluescoobywagon
