Processor Datasheets
first post..
Postby higB_0x05 » Thu Jan 20, 2005 3:00 pm
hey guys... i want to play... ive read a few threads on this board... but im having a hard time getting to the nitty-gritty.
-What hardware should I be using/building to interface with my ECU?
i can reverse engineer/debug/code/write exploits/ so some of those skills should translate ... i want to jump in feet first.. but dont know where to start.
higB_0x05
Postby bofh » Thu Jan 20, 2005 6:37 pm
In the tradition of usenet;
Me too!
Where is this kit we keep hearing about? :twisted:
bofh
Postby Imp Guerra » Sat Feb 05, 2005 2:14 pm
sorry,
I need pin-outs of Subaru ECU
AD 790
subaru legacy 2.2 wagon 1995MY US Market
see img at:
http://www.minsk555.narod.ru/ad790.htm
I need it to organize on-table tester for OBD-II ISO 9141 scanners
I need only pins for
-VCC
-Signal Ground
-K-line (7-pin line from OBD-II J1962 SAE connector)
Would you help me ?
Where the pinouts can be downloaded at ?
wbr
Guerra
subarums@mail.ru
Imp Guerra
Postby Ben Ogle » Mon Mar 13, 2006 11:52 am
Hey all. Do any of you know how the Denso part numbers are picked? Your processor on the first page turned out to be a motorola variant, and the processor in the 94-95 miatas has a similar part number (first 4 numbers the same):
D151804-0990
Do you think this is also motorola??
heres a pic:
http://forum.miata.net/vb/attachment.ph ... entid=4825
Ben
Ben Ogle
Postby cboles » Mon Mar 13, 2006 1:26 pm
You should be able to do a couple things to figure out that Miata ECU.
1. Look at what pins on the CPU are connected to power / ground / the crystal along with pin count and package style to figure out what CPU it is by comparing with available datasheets
2. Remove the EPROM and read it out with a PROM programmer to look at the code. You can also identify the CPU from the opcodes. There may also be ROM/FLASH inside the CPU, depends on the part.
Postby JonnyM » Mon Mar 13, 2006 8:44 pm
Most likely it is HD6301 + 27C256 in that ECU.
JonnyM
Postby brentb » Mon Mar 13, 2006 10:15 pm
Regarding this URL posted earlier in the thread,
http://www.brendan-stewart.com/other/subaruecu.htm ,
does anybody have the info from that page saved off anywhere? The domain is gone.
I've already looked at archive.org, but the page must have been newer than the snapshot there.
I'm curious what info was posted there.
brentb
Postby cboles » Tue Mar 14, 2006 10:01 am
Search this site. I have reposted it on here somewhere.
brentb wrote:Regarding this URL posted earlier in the thread,
Postby Jon [in CT] » Tue Mar 14, 2006 1:48 pm
A copy from Google's cache is at:
http://forums.openecu.org/download.php?id=70
Postby brentb » Tue Mar 14, 2006 2:30 pm
Thank you, interesting stuff.
I searched but it's hard to enter good search words when you don't exactly know what the content is.
brentb
Postby Ben Ogle » Sat Mar 18, 2006 12:25 am
JonnyM wrote:Most likely it is HD6301 + 27C256 in that ECU.
If you are talking to me, it looks a LOT like the motorola 68HC11K:
page 32 of
http://www.freescale.com/files/microcon ... 8HC11K.pdf
its 84 pin, starts the pin count from the middle of one side. The address lines look like they go to the eprom, and there is ground pad near the ground pin. I dont have one of these in my possession so I cant say for sure, otherwise I would dump the eprom and (try to) dasm it.
Does the HD6301 come in an 84 pin variant? I couldnt find one...
http://www.datasheetcatalog.net/cgi-bin ... ion=Search
Ben
Ben Ogle
Re: Processor Datasheets
Postby MarekW » Fri Dec 26, 2008 5:37 am
Hi,
I am still looking information about Denso ECU for mazda 323F (BJ) with diesel engine DITD.
The main chip is 151808-3663 (Denso) 120pins, XTAL 92,93 see picture:
Denso 151808-3663
Desno_151808-3663_uC (Medium).jpg (115.12 KiB) Viewed 13452 times
and in addition smaller chip but I do not know the purpose of it Desno , ESPD SE390 see picture
ESPD SE390
denso_ESPD_se390 (Medium).jpg (100.37 KiB) Viewed 13451 times
do you know any information?
In addition you can see the whole ECU:
MAZDA ECU RF4S for DITD
Added 3.1.2009
The main chip looks like Fujitsu F2MC-16LX 16-bits microcontroller, seria MB90570, 120pins.
Do you know how to directly connect to fujitsu processor, which softwer is good to use?
Best regards
M.
MarekW
