ecudef Leg/For/Imp 2.0 N/A DOHC EDM 05->
Postby sfaragdas » Fri Mar 11, 2011 2:09 pm
Hi
Is some one who can help me find or create XMLID [ECUID] to 2.0 DOHC from 158 to 165 ps. EDM model??
EcuFlash -> SSM2 ECU ID is 4E 44 30 71 06
<rom>
<romid>
<xmlid>A8DH100P</xmlid> -> ???????
<internalidaddress>2000</internalidaddress> -> propabil OK
<internalidstring>A8DH100P</internalidstring> -> ????????
<ecuid>4242504106</ecuid> -> 4E44307106
<year>06</year>
<market>EDM</market> ok
<make>Subaru</make> ok
<model>Forester</model> ok
<submodel>XT</submodel> ??
<transmission>AT</transmission> MT/AT
<memmodel>SH7058</memmodel> i thik that SH7058, cous SH7055 is older
<flashmethod>sti05</flashmethod> ok
<checksummodule>subarudbw</checksummodule> ok
</romid>
<include>32BITBASE</include> ok
is some one who know what have to be on ?? ?? ?? ;>
thx for help...
sfaragdas
Re: ecudef Leg/For/Imp 2.0 N/A DOHC EDM 05->
Postby Sasha_A80 » Fri Mar 11, 2011 10:27 pm
Is it Denso or Hitachi ecu?
Do you have the ROM image?
Sasha_A80
Postby sfaragdas » Mon Mar 14, 2011 7:59 am
Hi
no i don't have beacous ecuflash don't wont to get it...
Or is another soft with i will do it??
sfaragdas
Postby Sasha_A80 » Mon Mar 14, 2011 9:31 am
Complete ROM image of Hitachi NA ecu be may be probably got by means of SSM2 protocol.
Hitachi 22611-AJ610 ECU for NA EJ201 engine
http://www.romraider.com/forum/viewtopi ... =25&t=6940
Sasha_A80
Postby sfaragdas » Sun Mar 20, 2011 11:42 pm
Hi it's EJ204 like JDM engine??
viewtopic.php?f=3&t=4785&p=24144&hilit=ej204#p24144
the same problem... i can read from Forester XT from Tribeca, WRX but from this ECu i can't.... Help Please....
sfaragdas
Postby Sasha_A80 » Mon Mar 21, 2011 12:41 am
sfaragdas wrote:Hi it's EJ204 like JDM engine??
Do you also have Hitachi ecu?
This is based on M32R processor from Renesas.
ecuFlash currently enable to reflash those for Subaru.
Last year this was started for evoX ecu based on the same processor.
___EDITED___
ecuFlash currently is NOT ABLE to reflash those for Subaru.
It's my misprint.
Sasha_A80
Postby sfaragdas » Mon Mar 21, 2011 1:41 am
Hi Sasha_A80
I'm trying with connect and disconnect green connector (with and with out test mode) with all mitsubishi and subaru ways (STi 05, can EVOX, ...) and now way to do it...
If you know how can and wich way i have to do it please write it me ;-) i will be gratefuly ;-)
I was trying with EcuFlash 1.42 Released and 1.43 Betta and don't work...
sfaragdas
Postby Sasha_A80 » Mon Mar 21, 2011 5:28 am
OP2.0 does not help you currently.
You may try k-line adapter (OP1.3 for example) and use ecuQuery tool within ecuExplorer program.
Start address for reading is probably 0x080000.
Sasha_A80
Postby sfaragdas » Mon Mar 21, 2011 6:43 am
ok next example ;-)
it's too EJ204 EDM 165ps
Legacy My'08
i created xml file to subaru/Legacy 2.0R
[list=]<rom>
<romid>
<xmlid>BA9464B0</xmlid>
<internalidstring>BA9464B0</internalidstring>
<ecuid>4B44304006</ecuid>
<year>05</year>
<market>USDM</market>
<make>Subaru</make>
<model>Legacy</model>
<submodel>2.0</submodel>
<transmission>MT/AT</transmission>
</romid>
<include>BA9464B0</include>
</rom>[/list]
http://cmsk.net/OpenEcu/fail/BA9464B0.xml
and i tryed all method comunication with and with out test mode...
I don't have 1.3 ;/ only 2.0
is other soft to read and write rom from ecu wich is working with tactrix op2.0??
sfaragdas
Postby sfaragdas » Tue Mar 22, 2011 2:00 am
hi
in SSM3 i have finde some file:
http://cmsk.net/OpenEcu/H4DONA.mod
http://cmsk.net/OpenEcu/DBTO0001.dll
it is possible that there is key to this problem??
With orginal software from subaru FlashWrite i can with using Tactrix OP2.0 reprograming this ECU but only with .pak file eith are supported with this program...
So OP2.0 is compatibil with this ECU but problem is with EcuFlash comunication with this ECU ;-)
is some program who can edit FlashWire .pak file??
This is file with i reprograming with Tactrix with FlashWire in Legacy 2.0 EJ204 2006
http://cmsk.net/OpenEcu/22611AK773.pak
Is some one who can iteresting with this problem and can help me or us, cose im not one who has this problem ;-)
sfaragdas
Postby AmenoFils » Thu Apr 28, 2011 7:32 am
Hello guys,
I received my Subaru Legacy yesterday. For information it's not a 2011 it's a 2009 (an old stock they are selling for a good price).
I tried to connect with my OP2.0:
-With Evoscan the display isn't correct the value are changing too fast and are not correct for most of them.
-With PCMScan the connection is correct the DTC read is correct, the values seem to be correct.
-Tried to read the ROM with EcuFlash but I couldn't find where to plug the second connector, I tried anyway only with the OBDII cable and I heart a relay blinking in the right of the dash... very strange... so I stopped.
I'm ready to help into this topic in order to download the ROM and do some modifications...
AmenoFils
Postby sfaragdas » Thu Apr 28, 2011 10:28 am
hi AmenoFils
what kind of drivers are u using to connect with yours car?
1. Openport 2.0 driver and J2534 DLL
2. EcuFlash 1.42.2595
3. EcuFlash 1.43.3252??
did u used romraider logger?? its very nice... but only with 1 and secound driver
with 3. driver work free ssm and lumberjack,
did u find two green connectors?? under passager box neer ecu...
sfaragdas
Postby AmenoFils » Sun May 01, 2011 7:01 am
Hello sfaragdas,
Thanks for your answer...
I'm using the drivers that comes with the latest version of Ecuflash, and I didn't search yet for the green connector you're talking about, in my other car (mitsubishi CS1A)n the flashing connector is just near the OBD one... so I didn't find it in the Subaru.
I'll take a look for the connectors, (I ordered my cable with all the connectors) I'll try again to get the flash.
Thanks again for your help.
AmenoFils
