Does anybody know if these arethe right pinouts?
Postby condyboy » Wed Nov 26, 2008 4:15 am
Hi all I found this diagram for volvo v40td with a BOSCH EDC15C3 ecu.
I have translated the text with babelfish. I have asked on a few Volvo sites with no response.
My query is are the pinouts correct and do I just connect the K-LINE and L-LINE together?
thanks in advance.
Line given K transmission Connector 1 Pin C3 POSITIVE Connector 2 Pin M2 Pin E3 Pin D4 Connector 3 Pin A4 Mass carcass ECU NB.doc
(101 KiB) Downloaded 771 times
condyboy
Postby condyboy » Wed Nov 26, 2008 4:21 am
Sorry all the attachment has came up a bit wrong but the text is
Line given K transmission Connector 1 Pin C3 POSITIVE Connector 2 Pin M2 Pin E3 Pin D4 Connector 3 Pin A4 Mass carcass ECU NB. In connecting thorn EOBD II must lend attention in connecting Pin 7 to Pin 11 this procedure is only worth for this model of car Volvo V40
VOLVO V40
Linea K trasmissione dati
Connettore 1
Pin C3
POSITIVI
Connettore 2
Pin M2
Pin E3
Pin D4
Connettore 3
Pin A4
Massa carcassa ECU
NB.
Nel collegare la spina EOBD II bisogna prestare attenzione nel collegare il Pin 7 al Pin 11 questa procedura vale solo per questo modello di auto Volvo V40
VOLVO V40
Connettore 1
Pin C3
POSITIVI
Connettore 2
Pin M2
Pin E3
Pin D7
Connettore 3
Pin A4
Massa carcassa ECU
apologise it must be because the document was in MSWORD
condyboy
