ROM Definition 1.6L SOHC 4G92 Lancer GLXI 1997 (Asian)
Postby autozoom42 » Mon Nov 03, 2008 11:28 pm
Hi,
Does anyone has the rom definition of 1.6 L SOHC engine (4G92) GLXI Auto?
ECUflash cannot communicate with the ecu.
Can you help?
Thanks alot.
autozoom42
Re: ROM Definition 1.6L SOHC 4G92 Lancer GLXI 1997 (Asian)
Postby racedude » Thu Dec 31, 2009 1:56 am
Hi, I may be able to help. Where is your location?
racedude
Postby todd-w » Thu Dec 31, 2009 9:51 am
check the wire to the white flash connector , on some the lancers 96 on the wire doesnt go back to the ecu , it stops at the connector behind the dash on a right hand drive car if you take out the glove box and look up and to the left its one of the two block connectors in there usually green/white wire to pin 79 at the ecu.
todd-w
