XML Definition is not usable in ECUFlash1.3.1 onwards
Postby ccrash » Sat Sep 22, 2007 1:01 am
Hi Guys,
I'm facing issues with the current XML definition not being displayed properly in ECUFlash 1.3.1 onwards.
For example, the low det fuel and high det fuel is not displaying properly. If you select the injector flow scaling, the entire ECUFLASH crashed. There are others as well.
Take a look at the attachments.
Regards,
ccrash
High Det Fuel
Low Det Fuel
Injector Flow Scaling
ccrash
Postby Freon » Sat Sep 22, 2007 9:48 am
I believe Merchgod posted an update due to a bug in the definitions. Search his post history.
Postby merchgod » Sat Sep 22, 2007 3:33 pm
That's mitsu definitions which wouldn't have anything to do with the Subaru update. The endian attribute was fixed starting with Ecuflash 1.31. If you read the change list you'll see that it is not compatible with older definitions. You can fix this by going into the base xml and reversing every endian attribute in each scaling. That is, if it is little, change to big, and if it is big, change to little.
merchgod
Users browsing this forum: No registered users and 18 guests
