by swifty » Thu Aug 10, 2006 3:24 am
To be honest I haven't made any changes to the scales on my maps. I commented on yours because as far as I know they are always matched, at least in the ones I have seen have been anyway.
My jdm maps for fuel and ignition all go to load 5.6 and I haven't achieved this even with the boost turned up to 1.5 bar. 5.3 is about as high as it has got.
I took a lot of timing out initially while I was getting the AFR sorted out and experimenting with the boost levels, but my maps are still quite a bit more advanceed than yours. How close to det did you tune ?
I have also been using Optimax. I planned on tuning on that then I would also be able to use Tesco 99, but there is some talk of Optimax having been improved so is higher octane, so I'm no longer certain which way to go now. I think I will await the official announcement from Shell and go from there. In the meantime I'm back to the standard map as my tune wasn't finished and I now need to buy a new wideband.
