Unable to read/write using ECUFlash
Postby magnet » Tue Jul 09, 2013 7:53 pm
Hi guys, Im sorry if this is the wrong topic, but I was wondering if anyone knows what is wrong that I can't read map using ECU Flash. The Car is a 2004 JDM Subaru Impreza WRX MT/AT. A4TE200A, 3D04403005. I tried using both Tactrix 1.3 and 2.0 no luck. Green connector and jumper block connector already attached.
I tried reading on other cars, it works no problem except for this one. Any ideas?
[11:01:17.580] EcuFlash Version 1.44.3721
[11:01:17.580] OS Version Windows 7
[11:01:17.580] Qt Version 4.8.0
[11:01:17.587] 63 memory models read.
[11:01:17.588] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[11:01:17.720] 613 ROM metadata models scanned.
[11:01:17.720] checksum module "subarudbw" loaded.
[11:01:17.720] checksum module "mitsucan" loaded.
[11:01:17.720] checksum module "mitsuh8" loaded.
[11:01:17.720] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[11:01:17.720] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[11:01:17.722] flashing tool "wrx02" loaded.
[11:01:17.723] flashing tool "wrx04" loaded.
[11:01:17.725] flashing tool "sti04" loaded.
[11:01:17.726] flashing tool "sti05" loaded.
[11:01:17.726] flashing tool "mitsukernel" loaded.
[11:01:17.726] flashing tool "mitsukernelocp" loaded.
[11:01:17.726] flashing tool "mitsubootloader" loaded.
[11:01:17.726] flashing tool "shbootmode" loaded.
[11:01:17.727] flashing tool "shaudmode" loaded.
[11:01:17.729] flashing tool "subarucan" loaded.
[11:01:17.730] flashing tool "subarucand" loaded.
[11:01:17.732] flashing tool "mitsucan" loaded.
[11:01:17.750] J2534 API Version: 04.04
[11:01:17.750] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[11:01:17.750] Device Firmware Version: 1.12.3688
[11:01:17.750] Device Serial Number: TAN5i9Tm
[11:01:17.750] interface close
[11:01:17.774] J2534 API Version: 04.04
[11:01:17.774] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[11:01:17.774] Device Firmware Version: 1.12.3688
[11:01:17.774] Device Serial Number: TAN5i9Tm
[11:01:17.775] interface close
[11:01:17.798] J2534 API Version: 04.04
[11:01:17.798] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[11:01:17.798] Device Firmware Version: 1.12.3688
[11:01:17.798] Device Serial Number: TAN5i9Tm
[11:01:17.799] interface close
[11:02:17.612] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[11:02:17.629] J2534 API Version: 04.04
[11:02:17.629] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[11:02:17.629] Device Firmware Version: 1.12.3688
[11:02:17.629] Device Serial Number: TAN5i9Tm
[11:02:26.918] kernel get version
[11:02:27.120] interface close
[11:02:27.149] J2534 API Version: 04.04
[11:02:27.149] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[11:02:27.149] Device Firmware Version: 1.12.3688
[11:02:27.149] Device Serial Number: TAN5i9Tm
[11:02:27.340] interface close
[11:02:27.363] J2534 API Version: 04.04
[11:02:27.363] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[11:02:27.363] Device Firmware Version: 1.12.3688
[11:02:27.363] Device Serial Number: TAN5i9Tm
[11:02:27.520] SSM2 init
[11:02:27.681] SSM2 ECU ID is 3D04403005
[11:02:29.695] interface close
[11:02:29.707] interface close
magnet
Re: Unable to read/write using ECUFlash
Postby magnet » Tue Jul 09, 2013 7:57 pm
Here is another one using nonusdm_wrx "definition"?
[11:05:03.286] using metadata XML ID read_wrxnonusdm from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_wrxnonusdm.xml
[11:05:03.302] J2534 API Version: 04.04
[11:05:03.302] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[11:05:03.302] Device Firmware Version: 1.12.3688
[11:05:03.302] Device Serial Number: TAN5i9Tm
[11:05:09.137] denso02_bootloader_cmd_start
[11:05:10.356] denso02_bootloader_cmd_start
[11:05:11.574] denso02_bootloader_cmd_start
[11:05:12.793] denso02_bootloader_cmd_start
[11:05:14.015] denso02_bootloader_cmd_start
[11:05:14.422] kernel get version
[11:05:14.728] interface close
[11:05:14.745] interface close
magnet
