Voltage Issue
Voltage Issue
Postby TheHighestCrew » Fri Mar 29, 2013 10:32 am
Yesterday I was attempting to flash some tweaks I made to my map on my stg2 tune. Previously once I got the voltage too high error and was able to flash by turning the lights on. I am getting the same error. I have tried flashing probably 30-40 times now, going back to stock, the original stg2 map, and the latest one. Every time I am getting the voltage too high error. It does not say the voltage just that it is too high. Finally I had to give up and turn off the ignition.
I tried running every accessory in the car, radio all the way up, high beams on, defroster. Everything. Still the same damn error over and over. Starting to get SUPER pissed because it used to work fine. What could have happened?
I understand the ECU is possibly bricked now because I had to turn it off. I had no choice I did everything possible. I am now deleting and reinstalling the software on my laptop. Any help would be much appreciated.
A4sgc00c
memory model 68HC16Y5
kernel error: programming voltage is too high
failed to commit flash at (sometimes it is in the 00020000 range sometimes in the 00010000 range)
Test write is perfect every time. Then when I go to write it fails every time. Don't know what to do and my car is useless until I can fix this. Thanks for the help
TheHighestCrew
Re: Voltage Issue
Postby TheHighestCrew » Fri Mar 29, 2013 11:47 am
[13:00:51.882] EcuFlash Version 1.44.3721
[13:00:51.882] OS Version Windows 7
[13:00:51.882] Qt Version 4.8.0
[13:00:51.897] 63 memory models read.
[13:00:51.897] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[13:00:52.272] 611 ROM metadata models scanned.
[13:00:52.272] checksum module "subarudbw" loaded.
[13:00:52.272] checksum module "mitsucan" loaded.
[13:00:52.272] checksum module "mitsuh8" loaded.
[13:00:52.272] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[13:00:52.272] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[13:00:52.272] flashing tool "wrx02" loaded.
[13:00:52.272] flashing tool "wrx04" loaded.
[13:00:52.272] flashing tool "sti04" loaded.
[13:00:52.287] flashing tool "sti05" loaded.
[13:00:52.287] flashing tool "mitsukernel" loaded.
[13:00:52.287] flashing tool "mitsukernelocp" loaded.
[13:00:52.287] flashing tool "mitsubootloader" loaded.
[13:00:52.287] flashing tool "shbootmode" loaded.
[13:00:52.287] flashing tool "shaudmode" loaded.
[13:00:52.287] flashing tool "subarucan" loaded.
[13:00:52.287] flashing tool "subarucand" loaded.
[13:00:52.287] flashing tool "mitsucan" loaded.
[13:00:52.319] J2534 API Version: 04.04
[13:00:52.319] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:00:52.319] Device Firmware Version: 1.12.3688
[13:00:52.319] Device Serial Number: TAwpJoSR
[13:00:52.319] interface close
[13:00:52.350] J2534 API Version: 04.04
[13:00:52.350] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:00:52.350] Device Firmware Version: 1.12.3688
[13:00:52.350] Device Serial Number: TAwpJoSR
[13:00:52.350] interface close
[13:00:52.381] J2534 API Version: 04.04
[13:00:52.381] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:00:52.381] Device Firmware Version: 1.12.3688
[13:00:52.381] Device Serial Number: TAwpJoSR
[13:00:52.381] interface close
[13:01:46.763] using metadata XML ID read_wrx02 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_wrx02.xml
[13:01:46.794] J2534 API Version: 04.04
[13:01:46.794] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:01:46.794] Device Firmware Version: 1.12.3688
[13:01:46.794] Device Serial Number: TAwpJoSR
[13:01:58.381] denso02_bootloader_cmd_start
[13:01:58.693] writing kernel area addr: 020000 len: 0664
[13:02:00.611] kernel get version
[13:02:00.627] kernel version is : OpenECU Subaru HC16 Kernel V1.06
[13:02:00.627] reading kernel comm buffer size
[13:02:00.627] comm buffer size set to 512
[13:02:00.627] reading kernel flash buffer size
[13:02:00.643] flash buffer size set to 4096
[13:02:00.643] -- dumping ECU memory --
[13:02:00.721] kernel read area: addr: 00000000 len: 0200
[13:02:00.877] kernel read area: addr: 00000200 len: 0200
[13:02:01.017] kernel read area: addr: 00000400 len: 0200
[13:02:01.173] kernel read area: addr: 00000600 len: 0200
[13:02:01.329] kernel read area: addr: 00000800 len: 0200
[13:02:01.485] kernel read area: addr: 00000A00 len: 0200
[13:02:01.625] kernel read area: addr: 00000C00 len: 0200
[13:02:01.781] kernel read area: addr: 00000E00 len: 0200
[13:02:02.015] kernel read area: addr: 00001000 len: 0200
[13:02:02.171] kernel read area: addr: 00001200 len: 0200
[13:02:02.327] kernel read area: addr: 00001400 len: 0200
[13:02:02.468] kernel read area: addr: 00001600 len: 0200
[13:02:02.624] kernel read area: addr: 00001800 len: 0200
[13:02:02.780] kernel read area: addr: 00001A00 len: 0200
[13:02:02.920] kernel read area: addr: 00001C00 len: 0200
[13:02:03.076] kernel read area: addr: 00001E00 len: 0200
[13:02:03.310] kernel read area: addr: 00002000 len: 0200
[13:02:03.466] kernel read area: addr: 00002200 len: 0200
[13:02:03.622] kernel read area: addr: 00002400 len: 0200
[13:02:03.763] kernel read area: addr: 00002600 len: 0200
[13:02:03.919] kernel read area: addr: 00002800 len: 0200
[13:02:04.075] kernel read area: addr: 00002A00 len: 0200
[13:02:04.215] kernel read area: addr: 00002C00 len: 0200
[13:02:04.371] kernel read area: addr: 00002E00 len: 0200
[13:02:04.605] kernel read area: addr: 00003000 len: 0200
[13:02:04.761] kernel read area: addr: 00003200 len: 0200
[13:02:04.917] kernel read area: addr: 00003400 len: 0200
[13:02:05.058] kernel read area: addr: 00003600 len: 0200
[13:02:05.214] kernel read area: addr: 00003800 len: 0200
[13:02:05.370] kernel read area: addr: 00003A00 len: 0200
[13:02:05.510] kernel read area: addr: 00003C00 len: 0200
[13:02:05.666] kernel read area: addr: 00003E00 len: 0200
[13:02:05.900] kernel read area: addr: 00004000 len: 0200
[13:02:06.056] kernel read area: addr: 00004200 len: 0200
[13:02:06.212] kernel read area: addr: 00004400 len: 0200
[13:02:06.352] kernel read area: addr: 00004600 len: 0200
[13:02:06.508] kernel read area: addr: 00004800 len: 0200
[13:02:06.664] kernel read area: addr: 00004A00 len: 0200
[13:02:06.805] kernel read area: addr: 00004C00 len: 0200
[13:02:06.961] kernel read area: addr: 00004E00 len: 0200
[13:02:07.195] kernel read area: addr: 00005000 len: 0200
[13:02:07.351] kernel read area: addr: 00005200 len: 0200
[13:02:07.507] kernel read area: addr: 00005400 len: 0200
[13:02:07.647] kernel read area: addr: 00005600 len: 0200
[13:02:07.803] kernel read area: addr: 00005800 len: 0200
[13:02:07.959] kernel read area: addr: 00005A00 len: 0200
[13:02:08.100] kernel read area: addr: 00005C00 len: 0200
[13:02:08.256] kernel read area: addr: 00005E00 len: 0200
[13:02:08.490] kernel read area: addr: 00006000 len: 0200
[13:02:08.646] kernel read area: addr: 00006200 len: 0200
[13:02:08.802] kernel read area: addr: 00006400 len: 0200
[13:02:08.942] kernel read area: addr: 00006600 len: 0200
[13:02:09.098] kernel read area: addr: 00006800 len: 0200
[13:02:09.254] kernel read area: addr: 00006A00 len: 0200
[13:02:09.394] kernel read area: addr: 00006C00 len: 0200
[13:02:09.550] kernel read area: addr: 00006E00 len: 0200
[13:02:09.784] kernel read area: addr: 00007000 len: 0200
[13:02:09.940] kernel read area: addr: 00007200 len: 0200
[13:02:10.096] kernel read area: addr: 00007400 len: 0200
[13:02:10.237] kernel read area: addr: 00007600 len: 0200
[13:02:10.393] kernel read area: addr: 00007800 len: 0200
[13:02:10.549] kernel read area: addr: 00007A00 len: 0200
[13:02:10.689] kernel read area: addr: 00007C00 len: 0200
[13:02:10.845] kernel read area: addr: 00007E00 len: 0200
[13:02:11.079] kernel read area: addr: 00008000 len: 0200
[13:02:11.235] kernel read area: addr: 00008200 len: 0200
[13:02:11.391] kernel read area: addr: 00008400 len: 0200
[13:02:11.532] kernel read area: addr: 00008600 len: 0200
[13:02:11.688] kernel read area: addr: 00008800 len: 0200
[13:02:11.844] kernel read area: addr: 00008A00 len: 0200
[13:02:11.984] kernel read area: addr: 00008C00 len: 0200
[13:02:12.140] kernel read area: addr: 00008E00 len: 0200
[13:02:12.374] kernel read area: addr: 00009000 len: 0200
[13:02:12.530] kernel read area: addr: 00009200 len: 0200
[13:02:12.686] kernel read area: addr: 00009400 len: 0200
[13:02:12.826] kernel read area: addr: 00009600 len: 0200
[13:02:12.982] kernel read area: addr: 00009800 len: 0200
[13:02:13.138] kernel read area: addr: 00009A00 len: 0200
[13:02:13.279] kernel read area: addr: 00009C00 len: 0200
[13:02:13.435] kernel read area: addr: 00009E00 len: 0200
[13:02:13.669] kernel read area: addr: 0000A000 len: 0200
[13:02:13.825] kernel read area: addr: 0000A200 len: 0200
[13:02:13.981] kernel read area: addr: 0000A400 len: 0200
[13:02:14.121] kernel read area: addr: 0000A600 len: 0200
[13:02:14.277] kernel read area: addr: 0000A800 len: 0200
[13:02:14.433] kernel read area: addr: 0000AA00 len: 0200
[13:02:14.574] kernel read area: addr: 0000AC00 len: 0200
[13:02:14.730] kernel read area: addr: 0000AE00 len: 0200
[13:02:14.964] kernel read area: addr: 0000B000 len: 0200
[13:02:15.120] kernel read area: addr: 0000B200 len: 0200
[13:02:15.276] kernel read area: addr: 0000B400 len: 0200
[13:02:15.416] kernel read area: addr: 0000B600 len: 0200
[13:02:15.572] kernel read area: addr: 0000B800 len: 0200
[13:02:15.728] kernel read area: addr: 0000BA00 len: 0200
[13:02:15.868] kernel read area: addr: 0000BC00 len: 0200
[13:02:16.024] kernel read area: addr: 0000BE00 len: 0200
[13:02:16.258] kernel read area: addr: 0000C000 len: 0200
[13:02:16.414] kernel read area: addr: 0000C200 len: 0200
[13:02:16.570] kernel read area: addr: 0000C400 len: 0200
[13:02:16.711] kernel read area: addr: 0000C600 len: 0200
[13:02:16.867] kernel read area: addr: 0000C800 len: 0200
[13:02:17.023] kernel read area: addr: 0000CA00 len: 0200
[13:02:17.163] kernel read area: addr: 0000CC00 len: 0200
[13:02:17.319] kernel read area: addr: 0000CE00 len: 0200
[13:02:17.553] kernel read area: addr: 0000D000 len: 0200
[13:02:17.709] kernel read area: addr: 0000D200 len: 0200
[13:02:17.865] kernel read area: addr: 0000D400 len: 0200
[13:02:18.006] kernel read area: addr: 0000D600 len: 0200
[13:02:18.162] kernel read area: addr: 0000D800 len: 0200
[13:02:18.318] kernel read area: addr: 0000DA00 len: 0200
[13:02:18.458] kernel read area: addr: 0000DC00 len: 0200
[13:02:18.614] kernel read area: addr: 0000DE00 len: 0200
[13:02:18.848] kernel read area: addr: 0000E000 len: 0200
[13:02:19.004] kernel read area: addr: 0000E200 len: 0200
[13:02:19.160] kernel read area: addr: 0000E400 len: 0200
[13:02:19.300] kernel read area: addr: 0000E600 len: 0200
[13:02:19.456] kernel read area: addr: 0000E800 len: 0200
[13:02:19.612] kernel read area: addr: 0000EA00 len: 0200
[13:02:19.753] kernel read area: addr: 0000EC00 len: 0200
[13:02:19.909] kernel read area: addr: 0000EE00 len: 0200
[13:02:20.143] kernel read area: addr: 0000F000 len: 0200
[13:02:20.299] kernel read area: addr: 0000F200 len: 0200
[13:02:20.455] kernel read area: addr: 0000F400 len: 0200
[13:02:20.595] kernel read area: addr: 0000F600 len: 0200
[13:02:20.751] kernel read area: addr: 0000F800 len: 0200
[13:02:20.907] kernel read area: addr: 0000FA00 len: 0200
[13:02:21.048] kernel read area: addr: 0000FC00 len: 0200
[13:02:21.204] kernel read area: addr: 0000FE00 len: 0200
[13:02:21.438] kernel read area: addr: 00010000 len: 0200
[13:02:21.594] kernel read area: addr: 00010200 len: 0200
[13:02:21.750] kernel read area: addr: 00010400 len: 0200
[13:02:21.890] kernel read area: addr: 00010600 len: 0200
[13:02:22.046] kernel read area: addr: 00010800 len: 0200
[13:02:22.202] kernel read area: addr: 00010A00 len: 0200
[13:02:22.342] kernel read area: addr: 00010C00 len: 0200
[13:02:22.498] kernel read area: addr: 00010E00 len: 0200
[13:02:22.732] kernel read area: addr: 00011000 len: 0200
[13:02:22.888] kernel read area: addr: 00011200 len: 0200
[13:02:23.044] kernel read area: addr: 00011400 len: 0200
[13:02:23.185] kernel read area: addr: 00011600 len: 0200
[13:02:23.341] kernel read area: addr: 00011800 len: 0200
[13:02:23.497] kernel read area: addr: 00011A00 len: 0200
[13:02:23.637] kernel read area: addr: 00011C00 len: 0200
[13:02:23.793] kernel read area: addr: 00011E00 len: 0200
[13:02:24.027] kernel read area: addr: 00012000 len: 0200
[13:02:24.183] kernel read area: addr: 00012200 len: 0200
[13:02:24.339] kernel read area: addr: 00012400 len: 0200
[13:02:24.480] kernel read area: addr: 00012600 len: 0200
[13:02:24.636] kernel read area: addr: 00012800 len: 0200
[13:02:24.792] kernel read area: addr: 00012A00 len: 0200
[13:02:24.932] kernel read area: addr: 00012C00 len: 0200
[13:02:25.088] kernel read area: addr: 00012E00 len: 0200
[13:02:25.322] kernel read area: addr: 00013000 len: 0200
[13:02:25.478] kernel read area: addr: 00013200 len: 0200
[13:02:25.634] kernel read area: addr: 00013400 len: 0200
[13:02:25.774] kernel read area: addr: 00013600 len: 0200
[13:02:25.930] kernel read area: addr: 00013800 len: 0200
[13:02:26.086] kernel read area: addr: 00013A00 len: 0200
[13:02:26.227] kernel read area: addr: 00013C00 len: 0200
[13:02:26.383] kernel read area: addr: 00013E00 len: 0200
[13:02:26.617] kernel read area: addr: 00014000 len: 0200
[13:02:26.773] kernel read area: addr: 00014200 len: 0200
[13:02:26.929] kernel read area: addr: 00014400 len: 0200
[13:02:27.069] kernel read area: addr: 00014600 len: 0200
[13:02:27.225] kernel read area: addr: 00014800 len: 0200
[13:02:27.381] kernel read area: addr: 00014A00 len: 0200
[13:02:27.522] kernel read area: addr: 00014C00 len: 0200
[13:02:27.678] kernel read area: addr: 00014E00 len: 0200
[13:02:27.912] kernel read area: addr: 00015000 len: 0200
[13:02:28.068] kernel read area: addr: 00015200 len: 0200
[13:02:28.224] kernel read area: addr: 00015400 len: 0200
[13:02:28.364] kernel read area: addr: 00015600 len: 0200
[13:02:28.520] kernel read area: addr: 00015800 len: 0200
[13:02:28.676] kernel read area: addr: 00015A00 len: 0200
[13:02:28.816] kernel read area: addr: 00015C00 len: 0200
[13:02:28.972] kernel read area: addr: 00015E00 len: 0200
[13:02:29.206] kernel read area: addr: 00016000 len: 0200
[13:02:29.362] kernel read area: addr: 00016200 len: 0200
[13:02:29.518] kernel read area: addr: 00016400 len: 0200
[13:02:29.659] kernel read area: addr: 00016600 len: 0200
[13:02:29.815] kernel read area: addr: 00016800 len: 0200
[13:02:29.971] kernel read area: addr: 00016A00 len: 0200
[13:02:30.111] kernel read area: addr: 00016C00 len: 0200
[13:02:30.267] kernel read area: addr: 00016E00 len: 0200
[13:02:30.501] kernel read area: addr: 00017000 len: 0200
[13:02:30.657] kernel read area: addr: 00017200 len: 0200
[13:02:30.813] kernel read area: addr: 00017400 len: 0200
[13:02:30.954] kernel read area: addr: 00017600 len: 0200
[13:02:31.110] kernel read area: addr: 00017800 len: 0200
[13:02:31.266] kernel read area: addr: 00017A00 len: 0200
[13:02:31.406] kernel read area: addr: 00017C00 len: 0200
[13:02:31.562] kernel read area: addr: 00017E00 len: 0200
[13:02:31.796] kernel read area: addr: 00018000 len: 0200
[13:02:31.952] kernel read area: addr: 00018200 len: 0200
[13:02:32.108] kernel read area: addr: 00018400 len: 0200
[13:02:32.248] kernel read area: addr: 00018600 len: 0200
[13:02:32.404] kernel read area: addr: 00018800 len: 0200
[13:02:32.560] kernel read area: addr: 00018A00 len: 0200
[13:02:32.701] kernel read area: addr: 00018C00 len: 0200
[13:02:32.857] kernel read area: addr: 00018E00 len: 0200
[13:02:33.091] kernel read area: addr: 00019000 len: 0200
[13:02:33.247] kernel read area: addr: 00019200 len: 0200
[13:02:33.403] kernel read area: addr: 00019400 len: 0200
[13:02:33.543] kernel read area: addr: 00019600 len: 0200
[13:02:33.699] kernel read area: addr: 00019800 len: 0200
[13:02:33.855] kernel read area: addr: 00019A00 len: 0200
[13:02:33.996] kernel read area: addr: 00019C00 len: 0200
[13:02:34.152] kernel read area: addr: 00019E00 len: 0200
[13:02:34.386] kernel read area: addr: 0001A000 len: 0200
[13:02:34.542] kernel read area: addr: 0001A200 len: 0200
[13:02:34.698] kernel read area: addr: 0001A400 len: 0200
[13:02:34.838] kernel read area: addr: 0001A600 len: 0200
[13:02:34.994] kernel read area: addr: 0001A800 len: 0200
[13:02:35.150] kernel read area: addr: 0001AA00 len: 0200
[13:02:35.306] kernel read area: addr: 0001AC00 len: 0200
[13:02:35.446] kernel read area: addr: 0001AE00 len: 0200
[13:02:35.680] kernel read area: addr: 0001B000 len: 0200
[13:02:35.836] kernel read area: addr: 0001B200 len: 0200
[13:02:35.992] kernel read area: addr: 0001B400 len: 0200
[13:02:36.133] kernel read area: addr: 0001B600 len: 0200
[13:02:36.289] kernel read area: addr: 0001B800 len: 0200
[13:02:36.445] kernel read area: addr: 0001BA00 len: 0200
[13:02:36.601] kernel read area: addr: 0001BC00 len: 0200
[13:02:36.741] kernel read area: addr: 0001BE00 len: 0200
[13:02:36.975] kernel read area: addr: 0001C000 len: 0200
[13:02:37.131] kernel read area: addr: 0001C200 len: 0200
[13:02:37.287] kernel read area: addr: 0001C400 len: 0200
[13:02:37.428] kernel read area: addr: 0001C600 len: 0200
[13:02:37.584] kernel read area: addr: 0001C800 len: 0200
[13:02:37.740] kernel read area: addr: 0001CA00 len: 0200
[13:02:37.896] kernel read area: addr: 0001CC00 len: 0200
[13:02:38.036] kernel read area: addr: 0001CE00 len: 0200
[13:02:38.270] kernel read area: addr: 0001D000 len: 0200
[13:02:38.426] kernel read area: addr: 0001D200 len: 0200
[13:02:38.582] kernel read area: addr: 0001D400 len: 0200
[13:02:38.722] kernel read area: addr: 0001D600 len: 0200
[13:02:38.878] kernel read area: addr: 0001D800 len: 0200
[13:02:39.034] kernel read area: addr: 0001DA00 len: 0200
[13:02:39.190] kernel read area: addr: 0001DC00 len: 0200
[13:02:39.331] kernel read area: addr: 0001DE00 len: 0200
[13:02:39.565] kernel read area: addr: 0001E000 len: 0200
[13:02:39.721] kernel read area: addr: 0001E200 len: 0200
[13:02:39.877] kernel read area: addr: 0001E400 len: 0200
[13:02:40.033] kernel read area: addr: 0001E600 len: 0200
[13:02:40.173] kernel read area: addr: 0001E800 len: 0200
[13:02:40.329] kernel read area: addr: 0001EA00 len: 0200
[13:02:40.485] kernel read area: addr: 0001EC00 len: 0200
[13:02:40.626] kernel read area: addr: 0001EE00 len: 0200
[13:02:40.860] kernel read area: addr: 0001F000 len: 0200
[13:02:41.016] kernel read area: addr: 0001F200 len: 0200
[13:02:41.172] kernel read area: addr: 0001F400 len: 0200
[13:02:41.328] kernel read area: addr: 0001F600 len: 0200
[13:02:41.468] kernel read area: addr: 0001F800 len: 0200
[13:02:41.624] kernel read area: addr: 0001FA00 len: 0200
[13:02:41.780] kernel read area: addr: 0001FC00 len: 0200
[13:02:41.920] kernel read area: addr: 0001FE00 len: 0200
[13:02:42.154] kernel read area: addr: 00028000 len: 0200
[13:02:42.310] kernel read area: addr: 00028200 len: 0200
[13:02:42.466] kernel read area: addr: 00028400 len: 0200
[13:02:42.622] kernel read area: addr: 00028600 len: 0200
[13:02:42.763] kernel read area: addr: 00028800 len: 0200
[13:02:42.919] kernel read area: addr: 00028A00 len: 0200
[13:02:43.075] kernel read area: addr: 00028C00 len: 0200
[13:02:43.215] kernel read area: addr: 00028E00 len: 0200
[13:02:43.465] kernel read area: addr: 00029000 len: 0200
[13:02:43.605] kernel read area: addr: 00029200 len: 0200
[13:02:43.761] kernel read area: addr: 00029400 len: 0200
[13:02:43.917] kernel read area: addr: 00029600 len: 0200
[13:02:44.058] kernel read area: addr: 00029800 len: 0200
[13:02:44.214] kernel read area: addr: 00029A00 len: 0200
[13:02:44.370] kernel read area: addr: 00029C00 len: 0200
[13:02:44.510] kernel read area: addr: 00029E00 len: 0200
[13:02:44.760] kernel read area: addr: 0002A000 len: 0200
[13:02:44.900] kernel read area: addr: 0002A200 len: 0200
[13:02:45.056] kernel read area: addr: 0002A400 len: 0200
[13:02:45.212] kernel read area: addr: 0002A600 len: 0200
[13:02:45.352] kernel read area: addr: 0002A800 len: 0200
[13:02:45.508] kernel read area: addr: 0002AA00 len: 0200
[13:02:45.664] kernel read area: addr: 0002AC00 len: 0200
[13:02:45.805] kernel read area: addr: 0002AE00 len: 0200
[13:02:46.054] kernel read area: addr: 0002B000 len: 0200
[13:02:46.195] kernel read area: addr: 0002B200 len: 0200
[13:02:46.351] kernel read area: addr: 0002B400 len: 0200
[13:02:46.507] kernel read area: addr: 0002B600 len: 0200
[13:02:46.647] kernel read area: addr: 0002B800 len: 0200
[13:02:46.803] kernel read area: addr: 0002BA00 len: 0200
[13:02:46.959] kernel read area: addr: 0002BC00 len: 0200
[13:02:47.100] kernel read area: addr: 0002BE00 len: 0200
[13:02:47.349] kernel read area: addr: 0002C000 len: 0200
[13:02:47.490] kernel read area: addr: 0002C200 len: 0200
[13:02:47.646] kernel read area: addr: 0002C400 len: 0200
[13:02:47.802] kernel read area: addr: 0002C600 len: 0200
[13:02:47.958] kernel read area: addr: 0002C800 len: 0200
[13:02:48.114] kernel read area: addr: 0002CA00 len: 0200
[13:02:48.254] kernel read area: addr: 0002CC00 len: 0200
[13:02:48.410] kernel read area: addr: 0002CE00 len: 0200
[13:02:48.816] interface close
[13:02:48.847] interface close
[13:02:51.149] A4SGC00C (346 tables) inheriting 16BITBASE (561 tables)
[13:02:51.180] using metadata XML ID A4SGC00C from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/subaru/Impreza WRX/A4SGC00C.xml
which inherits XML ID 16BITBASE from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/subaru/Bases/16BITBASE.xml
[13:03:10.415] 163840 byte image read.
[13:03:10.415] using metadata XML ID A4SGC00C from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/subaru/Impreza WRX/A4SGC00C.xml
[13:03:36.389] J2534 API Version: 04.04
[13:03:36.389] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:03:36.389] Device Firmware Version: 1.12.3688
[13:03:36.389] Device Serial Number: TAwpJoSR
[13:03:39.620] denso02_bootloader_cmd_start
[13:03:40.852] denso02_bootloader_cmd_start
[13:03:42.085] denso02_bootloader_cmd_start
[13:03:43.317] denso02_bootloader_cmd_start
[13:03:44.550] denso02_bootloader_cmd_start
[13:03:44.971] kernel get version
[13:03:44.986] found oecu kernel!
[13:03:44.986] kernel already resident - skipping kernel load
[13:03:45.205] kernel get version
[13:03:45.220] kernel version is : OpenECU Subaru HC16 Kernel V1.06
[13:03:45.220] reading kernel comm buffer size
[13:03:45.236] comm buffer size set to 512
[13:03:45.236] reading kernel flash buffer size
[13:03:45.267] flash buffer size set to 4096
[13:03:45.267] -- flashing image to ECU memory --
[13:03:45.673] -- comparing ECU flash memory pages to image file --
[13:03:45.673] seg start len ecu CRC32 img CRC32 same?
[13:03:45.985] FB01 00000000 00004000 9E7D9C31 9E7D9C31 YES
[13:03:46.297] FB02 00004000 00004000 8F606882 8F606882 YES
[13:03:46.624] FB03 00008000 00004000 0216DE1B 0216DE1B YES
[13:03:46.936] FB04 0000C000 00004000 D3FE83A7 D3FE83A7 YES
[13:03:47.264] FB05 00010000 00004000 3ED4232E 3ED4232E YES
[13:03:47.576] FB06 00014000 00004000 9B898AB6 9B898AB6 YES
[13:03:47.904] FB07 00018000 00004000 939D0A27 939D0A27 YES
[13:03:48.216] FB08 0001C000 00004000 4BE24516 C58ED7E8 NO
[13:03:48.528] FB09 00028000 00004000 B9A6268E B9A6268E YES
[13:03:48.855] FB10 0002C000 00004000 55330EAF D220F13C NO
[13:03:49.183] kernel flash enable
[13:03:49.183] kernel blank flash page: addr: 0002C000
[13:03:49.401] erased in 1 pulse(s)
[13:03:49.401] kernel write flash buffer addr: 0002C000 len: 00000200
[13:03:49.542] kernel write flash buffer addr: 0002C200 len: 00000200
[13:03:49.682] kernel write flash buffer addr: 0002C400 len: 00000200
[13:03:49.822] kernel write flash buffer addr: 0002C600 len: 00000200
[13:03:49.947] kernel write flash buffer addr: 0002C800 len: 00000200
[13:03:50.088] kernel write flash buffer addr: 0002CA00 len: 00000200
[13:03:50.228] kernel write flash buffer addr: 0002CC00 len: 00000200
[13:03:50.368] kernel write flash buffer addr: 0002CE00 len: 00000200
[13:03:50.509] kernel commit flash addr: 0002C000 len: 00001000 crc32 8e930924
[13:03:50.883] written in 1 pulse(s)
[13:03:50.883] kernel write flash buffer addr: 0002D000 len: 00000200
[13:03:51.024] kernel write flash buffer addr: 0002D200 len: 00000200
[13:03:51.164] kernel write flash buffer addr: 0002D400 len: 00000200
[13:03:51.304] kernel write flash buffer addr: 0002D600 len: 00000200
[13:03:51.445] kernel write flash buffer addr: 0002D800 len: 00000200
[13:03:51.585] kernel write flash buffer addr: 0002DA00 len: 00000200
[13:03:51.710] kernel write flash buffer addr: 0002DC00 len: 00000200
[13:03:51.850] kernel write flash buffer addr: 0002DE00 len: 00000200
[13:03:51.991] kernel commit flash addr: 0002D000 len: 00001000 crc32 56a4f516
[13:03:52.084] kernel error: programming voltage is too high
[13:03:52.084] failed to commit flash at 0002D000!
[13:03:52.084] failure in flashing block
[13:03:52.084] kernel flash disable
[13:03:52.100] interface close
[13:03:52.116] interface close
[13:04:49.208] J2534 API Version: 04.04
[13:04:49.208] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:04:49.208] Device Firmware Version: 1.12.3688
[13:04:49.208] Device Serial Number: TAwpJoSR
[13:04:52.555] denso02_bootloader_cmd_start
[13:04:53.788] denso02_bootloader_cmd_start
[13:04:55.020] denso02_bootloader_cmd_start
[13:04:56.253] denso02_bootloader_cmd_start
[13:04:57.485] denso02_bootloader_cmd_start
[13:04:57.906] kernel get version
[13:04:57.922] found oecu kernel!
[13:04:57.922] kernel already resident - skipping kernel load
[13:04:58.140] kernel get version
[13:04:58.140] kernel version is : OpenECU Subaru HC16 Kernel V1.06
[13:04:58.140] reading kernel comm buffer size
[13:04:58.156] comm buffer size set to 512
[13:04:58.156] reading kernel flash buffer size
[13:04:58.187] flash buffer size set to 4096
[13:04:58.187] -- flashing image to ECU memory --
[13:04:58.593] -- comparing ECU flash memory pages to image file --
[13:04:58.593] seg start len ecu CRC32 img CRC32 same?
[13:04:58.905] FB01 00000000 00004000 9E7D9C31 9E7D9C31 YES
[13:04:59.217] FB02 00004000 00004000 8F606882 8F606882 YES
[13:04:59.544] FB03 00008000 00004000 0216DE1B 0216DE1B YES
[13:04:59.856] FB04 0000C000 00004000 D3FE83A7 D3FE83A7 YES
[13:05:00.184] FB05 00010000 00004000 3ED4232E 3ED4232E YES
[13:05:00.496] FB06 00014000 00004000 9B898AB6 9B898AB6 YES
[13:05:00.823] FB07 00018000 00004000 939D0A27 939D0A27 YES
[13:05:01.135] FB08 0001C000 00004000 4BE24516 C58ED7E8 NO
[13:05:01.463] FB09 00028000 00004000 B9A6268E B9A6268E YES
[13:05:01.775] FB10 0002C000 00004000 55330EAF D220F13C NO
[13:05:02.103] kernel flash enable
[13:05:02.103] kernel blank flash page: addr: 0002C000
[13:05:02.321] erased in 1 pulse(s)
[13:05:02.321] kernel write flash buffer addr: 0002C000 len: 00000200
[13:05:02.461] kernel write flash buffer addr: 0002C200 len: 00000200
[13:05:02.602] kernel write flash buffer addr: 0002C400 len: 00000200
[13:05:02.742] kernel write flash buffer addr: 0002C600 len: 00000200
[13:05:02.867] kernel write flash buffer addr: 0002C800 len: 00000200
[13:05:03.007] kernel write flash buffer addr: 0002CA00 len: 00000200
[13:05:03.148] kernel write flash buffer addr: 0002CC00 len: 00000200
[13:05:03.288] kernel write flash buffer addr: 0002CE00 len: 00000200
[13:05:03.429] kernel commit flash addr: 0002C000 len: 00001000 crc32 8e930924
[13:05:03.803] written in 1 pulse(s)
[13:05:03.803] kernel write flash buffer addr: 0002D000 len: 00000200
[13:05:03.943] kernel write flash buffer addr: 0002D200 len: 00000200
[13:05:04.084] kernel write flash buffer addr: 0002D400 len: 00000200
[13:05:04.224] kernel write flash buffer addr: 0002D600 len: 00000200
[13:05:04.365] kernel write flash buffer addr: 0002D800 len: 00000200
[13:05:04.505] kernel write flash buffer addr: 0002DA00 len: 00000200
[13:05:04.630] kernel write flash buffer addr: 0002DC00 len: 00000200
[13:05:04.770] kernel write flash buffer addr: 0002DE00 len: 00000200
[13:05:04.911] kernel commit flash addr: 0002D000 len: 00001000 crc32 56a4f516
[13:05:05.301] written in 1 pulse(s)
[13:05:05.301] kernel write flash buffer addr: 0002E000 len: 00000200
[13:05:05.425] kernel write flash buffer addr: 0002E200 len: 00000200
[13:05:05.566] kernel write flash buffer addr: 0002E400 len: 00000200
[13:05:05.706] kernel write flash buffer addr: 0002E600 len: 00000200
[13:05:05.847] kernel write flash buffer addr: 0002E800 len: 00000200
[13:05:05.987] kernel write flash buffer addr: 0002EA00 len: 00000200
[13:05:06.127] kernel write flash buffer addr: 0002EC00 len: 00000200
[13:05:06.268] kernel write flash buffer addr: 0002EE00 len: 00000200
[13:05:06.393] kernel commit flash addr: 0002E000 len: 00001000 crc32 928990d2
[13:05:06.783] written in 1 pulse(s)
[13:05:06.783] kernel write flash buffer addr: 0002F000 len: 00000200
[13:05:06.923] kernel write flash buffer addr: 0002F200 len: 00000200
[13:05:07.063] kernel write flash buffer addr: 0002F400 len: 00000200
[13:05:07.188] kernel write flash buffer addr: 0002F600 len: 00000200
[13:05:07.329] kernel write flash buffer addr: 0002F800 len: 00000200
[13:05:07.469] kernel write flash buffer addr: 0002FA00 len: 00000200
[13:05:07.609] kernel write flash buffer addr: 0002FC00 len: 00000200
[13:05:07.750] kernel write flash buffer addr: 0002FE00 len: 00000200
[13:05:07.890] kernel commit flash addr: 0002F000 len: 00001000 crc32 fc87c6e5
[13:05:07.968] kernel error: programming voltage is too high
[13:05:07.968] failed to commit flash at 0002F000!
[13:05:07.968] failure in flashing block
[13:05:07.968] kernel flash disable
[13:05:08.015] interface close
[13:05:08.046] interface close
[13:05:28.889] J2534 API Version: 04.04
[13:05:28.889] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:05:28.889] Device Firmware Version: 1.12.3688
[13:05:28.889] Device Serial Number: TAwpJoSR
[13:05:31.592] denso02_bootloader_cmd_start
[13:05:32.824] denso02_bootloader_cmd_start
[13:05:34.057] denso02_bootloader_cmd_start
[13:05:35.289] denso02_bootloader_cmd_start
[13:05:36.521] denso02_bootloader_cmd_start
[13:05:36.943] kernel get version
[13:05:36.958] found oecu kernel!
[13:05:36.958] kernel already resident - skipping kernel load
[13:05:37.177] kernel get version
[13:05:37.192] kernel version is : OpenECU Subaru HC16 Kernel V1.06
[13:05:37.192] reading kernel comm buffer size
[13:05:37.192] comm buffer size set to 512
[13:05:37.192] reading kernel flash buffer size
[13:05:37.208] flash buffer size set to 4096
[13:05:37.208] -- flashing image to ECU memory --
[13:05:37.613] -- comparing ECU flash memory pages to image file --
[13:05:37.613] seg start len ecu CRC32 img CRC32 same?
[13:05:37.925] FB01 00000000 00004000 9E7D9C31 9E7D9C31 YES
[13:05:38.237] FB02 00004000 00004000 8F606882 8F606882 YES
[13:05:38.565] FB03 00008000 00004000 0216DE1B 0216DE1B YES
[13:05:38.877] FB04 0000C000 00004000 D3FE83A7 D3FE83A7 YES
[13:05:39.205] FB05 00010000 00004000 3ED4232E 3ED4232E YES
[13:05:39.517] FB06 00014000 00004000 9B898AB6 9B898AB6 YES
[13:05:39.844] FB07 00018000 00004000 939D0A27 939D0A27 YES
[13:05:40.156] FB08 0001C000 00004000 4BE24516 C58ED7E8 NO
[13:05:40.468] FB09 00028000 00004000 B9A6268E B9A6268E YES
[13:05:40.796] FB10 0002C000 00004000 DFF350D3 D220F13C NO
[13:05:41.123] kernel flash enable
[13:05:41.123] kernel blank flash page: addr: 0002C000
[13:05:41.342] erased in 1 pulse(s)
[13:05:41.342] kernel write flash buffer addr: 0002C000 len: 00000200
[13:05:41.482] kernel write flash buffer addr: 0002C200 len: 00000200
[13:05:41.623] kernel write flash buffer addr: 0002C400 len: 00000200
[13:05:41.763] kernel write flash buffer addr: 0002C600 len: 00000200
[13:05:41.888] kernel write flash buffer addr: 0002C800 len: 00000200
[13:05:42.028] kernel write flash buffer addr: 0002CA00 len: 00000200
[13:05:42.169] kernel write flash buffer addr: 0002CC00 len: 00000200
[13:05:42.309] kernel write flash buffer addr: 0002CE00 len: 00000200
[13:05:42.449] kernel commit flash addr: 0002C000 len: 00001000 crc32 8e930924
[13:05:42.824] written in 1 pulse(s)
[13:05:42.824] kernel write flash buffer addr: 0002D000 len: 00000200
[13:05:42.964] kernel write flash buffer addr: 0002D200 len: 00000200
[13:05:43.105] kernel write flash buffer addr: 0002D400 len: 00000200
[13:05:43.245] kernel write flash buffer addr: 0002D600 len: 00000200
[13:05:43.385] kernel write flash buffer addr: 0002D800 len: 00000200
[13:05:43.526] kernel write flash buffer addr: 0002DA00 len: 00000200
[13:05:43.666] kernel write flash buffer addr: 0002DC00 len: 00000200
[13:05:43.791] kernel write flash buffer addr: 0002DE00 len: 00000200
[13:05:43.931] kernel commit flash addr: 0002D000 len: 00001000 crc32 56a4f516
[13:05:44.321] written in 1 pulse(s)
[13:05:44.321] kernel write flash buffer addr: 0002E000 len: 00000200
[13:05:44.462] kernel write flash buffer addr: 0002E200 len: 00000200
[13:05:44.602] kernel write flash buffer addr: 0002E400 len: 00000200
[13:05:44.727] kernel write flash buffer addr: 0002E600 len: 00000200
[13:05:44.867] kernel write flash buffer addr: 0002E800 len: 00000200
[13:05:45.008] kernel write flash buffer addr: 0002EA00 len: 00000200
[13:05:45.148] kernel write flash buffer addr: 0002EC00 len: 00000200
[13:05:45.289] kernel write flash buffer addr: 0002EE00 len: 00000200
[13:05:45.429] kernel commit flash addr: 0002E000 len: 00001000 crc32 928990d2
[13:05:45.803] written in 1 pulse(s)
[13:05:45.803] kernel write flash buffer addr: 0002F000 len: 00000200
[13:05:45.944] kernel write flash buffer addr: 0002F200 len: 00000200
[13:05:46.084] kernel write flash buffer addr: 0002F400 len: 00000200
[13:05:46.225] kernel write flash buffer addr: 0002F600 len: 00000200
[13:05:46.365] kernel write flash buffer addr: 0002F800 len: 00000200
[13:05:46.490] kernel write flash buffer addr: 0002FA00 len: 00000200
[13:05:46.630] kernel write flash buffer addr: 0002FC00 len: 00000200
[13:05:46.771] kernel write flash buffer addr: 0002FE00 len: 00000200
[13:05:46.911] kernel commit flash addr: 0002F000 len: 00001000 crc32 fc87c6e5
[13:05:46.989] kernel error: programming voltage is too high
[13:05:46.989] failed to commit flash at 0002F000!
[13:05:46.989] failure in flashing block
[13:05:46.989] kernel flash disable
[13:05:47.005] interface close
[13:05:47.020] interface close
[13:06:36.562] J2534 API Version: 04.04
[13:06:36.562] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:06:36.562] Device Firmware Version: 1.12.3688
[13:06:36.562] Device Serial Number: TAwpJoSR
[13:06:38.945] denso02_bootloader_cmd_start
[13:06:40.177] denso02_bootloader_cmd_start
[13:06:41.410] denso02_bootloader_cmd_start
[13:06:42.642] denso02_bootloader_cmd_start
[13:06:43.874] denso02_bootloader_cmd_start
[13:06:44.296] kernel get version
[13:06:44.311] found oecu kernel!
[13:06:44.311] kernel already resident - skipping kernel load
[13:06:44.530] kernel get version
[13:06:44.530] kernel version is : OpenECU Subaru HC16 Kernel V1.06
[13:06:44.530] reading kernel comm buffer size
[13:06:44.561] comm buffer size set to 512
[13:06:44.561] reading kernel flash buffer size
[13:06:44.576] flash buffer size set to 4096
[13:06:44.576] -- flashing image to ECU memory --
[13:06:44.982] -- comparing ECU flash memory pages to image file --
[13:06:44.982] seg start len ecu CRC32 img CRC32 same?
[13:06:45.294] FB01 00000000 00004000 9E7D9C31 9E7D9C31 YES
[13:06:45.606] FB02 00004000 00004000 8F606882 8F606882 YES
[13:06:45.934] FB03 00008000 00004000 0216DE1B 0216DE1B YES
[13:06:46.246] FB04 0000C000 00004000 D3FE83A7 D3FE83A7 YES
[13:06:46.573] FB05 00010000 00004000 3ED4232E 3ED4232E YES
[13:06:46.885] FB06 00014000 00004000 9B898AB6 9B898AB6 YES
[13:06:47.213] FB07 00018000 00004000 939D0A27 939D0A27 YES
[13:06:47.525] FB08 0001C000 00004000 4BE24516 C58ED7E8 NO
[13:06:47.852] FB09 00028000 00004000 B9A6268E B9A6268E YES
[13:06:48.164] FB10 0002C000 00004000 DFF350D3 D220F13C NO
[13:06:48.492] kernel flash enable
[13:06:48.492] kernel blank flash page: addr: 0002C000
[13:06:48.710] erased in 1 pulse(s)
[13:06:48.710] kernel write flash buffer addr: 0002C000 len: 00000200
[13:06:48.851] kernel write flash buffer addr: 0002C200 len: 00000200
[13:06:48.991] kernel write flash buffer addr: 0002C400 len: 00000200
[13:06:49.132] kernel write flash buffer addr: 0002C600 len: 00000200
[13:06:49.256] kernel write flash buffer addr: 0002C800 len: 00000200
[13:06:49.397] kernel write flash buffer addr: 0002CA00 len: 00000200
[13:06:49.537] kernel write flash buffer addr: 0002CC00 len: 00000200
[13:06:49.678] kernel write flash buffer addr: 0002CE00 len: 00000200
[13:06:49.818] kernel commit flash addr: 0002C000 len: 00001000 crc32 8e930924
[13:06:49.896] kernel error: programming voltage is too high
[13:06:49.896] failed to commit flash at 0002C000!
[13:06:49.896] failure in flashing block
[13:06:49.896] kernel flash disable
[13:06:49.943] interface close
[13:06:49.958] interface close
[13:07:30.582] J2534 API Version: 04.04
[13:07:30.582] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:07:30.582] Device Firmware Version: 1.12.3688
[13:07:30.582] Device Serial Number: TAwpJoSR
[13:07:54.125] denso02_bootloader_cmd_start
[13:07:54.437] writing kernel area addr: 020000 len: 0664
[13:07:56.355] kernel get version
[13:07:56.355] kernel version is : OpenECU Subaru HC16 Kernel V1.06
[13:07:56.355] reading kernel comm buffer size
[13:07:56.387] comm buffer size set to 512
[13:07:56.387] reading kernel flash buffer size
[13:07:56.402] flash buffer size set to 4096
[13:07:56.402] -- flashing image to ECU memory --
[13:07:56.808] -- comparing ECU flash memory pages to image file --
[13:07:56.808] seg start len ecu CRC32 img CRC32 same?
[13:07:57.120] FB01 00000000 00004000 9E7D9C31 9E7D9C31 YES
[13:07:57.432] FB02 00004000 00004000 8F606882 8F606882 YES
[13:07:57.759] FB03 00008000 00004000 0216DE1B 0216DE1B YES
[13:07:58.071] FB04 0000C000 00004000 D3FE83A7 D3FE83A7 YES
[13:07:58.399] FB05 00010000 00004000 3ED4232E 3ED4232E YES
[13:07:58.711] FB06 00014000 00004000 9B898AB6 9B898AB6 YES
[13:07:59.039] FB07 00018000 00004000 939D0A27 939D0A27 YES
[13:07:59.351] FB08 0001C000 00004000 4BE24516 C58ED7E8 NO
[13:07:59.663] FB09 00028000 00004000 B9A6268E B9A6268E YES
[13:07:59.990] FB10 0002C000 00004000 690B37D3 D220F13C NO
[13:08:00.318] kernel flash enable
[13:08:00.318] kernel blank flash page: addr: 0002C000
[13:08:00.333] kernel error: programming voltage is too high
[13:08:00.333] WARNING: failed to erase page at 0002C000!
[13:08:00.333] kernel flash disable
[13:08:00.349] interface close
[13:08:00.365] interface close
TheHighestCrew
Re: Voltage Issue
Postby TheHighestCrew » Fri Mar 29, 2013 12:52 pm
update-
Got in contact with tactrix today and they want to send me a new one and me send in the old one. After reviewing my logs they think the ECU is not bricked but car will not start until i can reflash. Hoping that it is a problem in the hardware and that I am good to go with the new cable.
TheHighestCrew
Re: Voltage Issue
Postby mporeda » Fri Apr 05, 2013 2:21 pm
In case anyone else ever sees an error complaining of too high voltage, that doesn't mean the car voltage, but rather it's referring to the programming voltage generated by the OpenPort. Turning accessories on to reduce the car's battery voltage won't have any affect on that error.
mporeda
Re: Voltage Issue
Postby throttlehappy » Sat Jul 13, 2013 8:16 pm
Sorry, I posted this elsewhere but it is more appropriate here:
Another issue
Constant Voltage Errors on the 16Bit ECU. I had 13.6V and got a Voltage is too low error, same response on 12.2 although occassionally get voltage too high but in the last few weeks I am yet to flash a 16bit ECU... ever since upgrading the tactrix Firmware in 1.44. I have done the 12V feed from a regulated power source to flash connector but no dice :(
I have my old tactrix OP2.0 that works fine on my old laptop running 1.43 and I have avoided connecting the old tactrix to new laptop since back to back the old one works flawlessly, even if bootloader is loaded with new setup and voltage error occurs, I can plug in old laptop + old tactrix OP2.0 and it will work fine on the first go.
Uninstalled 1.44 and gone back to 1.43 but would like to know which USB/Tactrix drivers to delete/remove on new laptop? I uninstalled the Tactrix Drivers in Programs but I cannot risk that other files may be present as this is my only 'old' tactrix left!
throttlehappy
