Openport 2.0 no response f ECU WRX
Postby vp83 » Sat Jun 30, 2012 3:55 am
Hi, everyone!
I try to read DTSc with evoscan with OP2.0 but
EcuFlash seems to work, but when I try Display DTCs with Evoscan it gives me:
Info: OpenPort 2.0 Found.
Info: OpenPort Firmware v1.11.320
Info: Battery 13.572V
Info: Initialize Vehicle ECU...
Info: OBDII Connecting...
Info: Initializing At 5 baud...
Info: Initialization Complete...
Info: OBDII Sync Byte Received.
Info: Keybyte Response: 0x08 0x08
Info: OBDII Keyword CRC Received.
Info: Waiting for vehicle ecu...
Info: Connecting...
Info: Battery 13.659V
Info: No Response from Vehicle ECU
Info: Check DTCs Complete.
So DTCs give me:
battery is new, voltage ok
does I miss some install data? drivers?
first I Install EcuFlash then EvoScan, then reinstal those few times
I tried EvoScan 2.8 and 2.9
the same
what does I miss?
vp83
Users browsing this forum: No registered users and 50 guests
