Removing OpenECU Tune
Postby puma » Mon May 28, 2012 2:30 pm
Hi
Bit of a random question here I can't imagine many people would want to do this as I can't seem to find any info on there about it.
I have an 02 wrx that i bought with an open ECU tune. Now I need to return the car to stock (basically just an turbo back exhaust) so I would like to be able to remove the tune also.
1) Is this possible to do.
2) What will I require to do it easily I don't really want to spend money to do it.
Thanks for you help
Cheers
puma
Re: Removing OpenECU Tune
Postby radsdau » Mon May 28, 2012 8:54 pm
1. Absolutely.
2. Find someone with an OpenPort cable and a laptop that runs ECUFlash. Find the stock def for your car and ask them to flash it in. Should take all of 2 minutes.
Postby puma » Tue May 29, 2012 3:42 pm
Thanks for your help so far I think I might be able to take care of it myself. I have been doing a bit of reading and watching and have an idea on what to do now.
However where would I get the standard defs from?
puma
Postby radsdau » Wed May 30, 2012 3:37 pm
puma wrote:... However where would I get the standard defs from?
My bad- I meant standard ROM. Lots of places, either search this forum for your rom code, or romraider, or scoobypedia. If all else fails request it here; someone will have it.
Cheers.
