Data logging mivec, help...
Postby logan333 » Tue Apr 19, 2011 11:39 am
I had my 93 mivec mirage hooked up to datalogging software (technomotive) and recorded a few 3rd and 4th gear pulls to redline.
After going over the data the o2 was reading steady 0.9volts (stock narrow band) while on WOT, the timing was around the 25degrees through the top end rev range on WOT and the knock was off the charts don’t quite know what it was measured in but read about 120 knock sum on idle and 230 while nailing it?? Could it be faulty or is there something seriously wrong? Also interesting the throttle position only ever gets to 96%
Ill add that the car is running on 95 durning this log.
It runs perfect, idle, driving, full throttle etc
Done a 15.1 1/4 mile so no lack of power or misfiring
http://img198.imageshack.us/f/logans2ndgear.png/
http://img846.imageshack.us/f/logan3rdgear.png/
http://img534.imageshack.us/i/logan4thgear.png/
the knock is way off the charts....
logan333
