need help can reflash my wrx 2005
Postby srpshop » Thu Dec 16, 2010 9:53 am
good morning when i reflash my wrx 05 i have a proble3m i can take the rom put of the ecu but after i modify the rom i im trying to reflash back and i have a error this is the error
[13:08:21.453] J2534 API Version: 04.04
[13:08:21.453] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[13:08:21.453] Device Firmware Version: 1.11.3157
[13:08:24.828] denso02_bootloader_cmd_start
[13:08:25.140] writing kernel area addr: 020000 len: 0664
[13:08:27.062] kernel get version
[13:08:27.078] kernel version is : OpenECU Subaru HC16 Kernel V1.06
[13:08:27.078] reading kernel comm buffer size
[13:08:27.093] comm buffer size set to 512
[13:08:27.093] reading kernel flash buffer size
[13:08:27.093] flash buffer size set to 4096
[13:08:27.093] -- flashing image to ECU memory --
[13:08:27.500] -- comparing ECU flash memory pages to image file --
[13:08:27.500] seg start len ecu CRC32 img CRC32 same?
[13:08:27.812] FB01 00000000 00004000 FD40A27D FD40A27D YES
[13:08:28.140] FB02 00004000 00004000 2D447BD0 2D447BD0 YES
[13:08:28.468] FB03 00008000 00004000 AC08E666 AC08E666 YES
[13:08:28.781] FB04 0000C000 00004000 F6FF82E2 F6FF82E2 YES
[13:08:29.109] FB05 00010000 00004000 DE064EE4 DE064EE4 YES
[13:08:29.421] FB06 00014000 00004000 2B9F3825 2B9F3825 YES
[13:08:29.750] FB07 00018000 00004000 24B1156C 24B1156C YES
[13:08:30.062] FB08 0001C000 00004000 7259CC9A 7259CC9A YES
[13:08:30.390] FB09 00028000 00004000 62A16972 4A184D3E NO
[13:08:30.703] FB10 0002C000 00004000 4ACE4000 B803695C NO
[13:08:31.031] reading ecu programming voltage
[13:08:31.031] programming voltage is 4.42 volts
[13:08:31.031] programming voltage is out of range!
[13:08:31.031] interface close
[13:08:31.046] interface close
what can i do
srpshop
Re: need help can reflash my wrx 2005
Postby radsdau » Sun Dec 19, 2010 8:10 pm
Sounds like a faulty OpenPort cable, or the flash jumper block isn't installed (more likely).
Users browsing this forum: Google [Bot] and 49 guests
