97 mirage 1.8 tried swapping in a evo8 ecu
Postby miksatx » Thu Sep 23, 2010 4:10 pm
can anyone tell me why i can't get this to work? the ecu in it is in a metal case MD prefix. i swapped pin 8 and 22 like other mirages can do. i ran a plug from pin 79 so i could flash the evo8 ecu. i can read and write. but when i pull up evoscan and do actuator test. all test come back no response from ecu. did all the immobilizers stuff. so i've more less gave up on the 97. i don't see anything different from the 97 ecu pinout as to the 98 ecu pinout. you can swap out 98 to 01 mirages with the evo 8 no problem
miksatx
Users browsing this forum: Google [Bot] and 22 guests
