OpenPort 2.0 for Honda Diagnostic System
Postby yungming » Mon Oct 05, 2009 12:24 pm
Hi there
I read some info from FitFreak.net forum that there is a special driver for the openport 2.0 to work with the honda diagnostic system software and also the CM Update software.
I am interested to trick the ECU to read the wrong code and flash it to another calibration files. What are the tools I need? Where can I get the special driver to work with the CM Update software and how to trick it? What software to use to trick the ECU to read the wrong ECU model code?
Help needed. I hope the OpenPort 2.0 hardware and software will work and this is the thing I am looking for
yungming
Re: OpenPort 2.0 for Honda Diagnostic System
Postby Ahandy1 » Sat Jul 12, 2014 10:45 pm
Hello there,
Did you have any luck with this setup? I am in the same boat now and would like to know if this can be done.
Please share your results.
Thanks.
Ahandy1
