Hello Everyone;
I purchased an Openport 2.0 few months back, but had problems registering myself on this forum due to "IP not allowed to register". I sent several emails to Amanda on this matter, and thanks to whoever making this registration possible now.
I own a Kia with BETA II 2.0L engine, CVVT on the intake side. Initially, I had thought that since Hyundai/Kia (H/K) colloborated with Mitsu on their earlier models, Openport 2.0 would work on this ECU .... but not so. Base on my research on the www, some say that the H/K ecu codes are impossible . I would like to share the following, and I hope that others will chip in as well to make the Openport2.0 and Ecuflash software workable for H/K.
First of all, I found the following ref. helpfull in communicating with the ECU;
viewtopic.php?f=4&t=3646&p=18990&hilit=iso9141#p18990
Apparently, KWP2000 protocol is quite user friendly. My understanding is that, it even allow the user to download & flash the parameters. If this is true, I will only need an ELM327 or MobyDic to download & upload. I am sure Openport2.0 can do that too as it is KWP2000 compliant. But I have not come across any "Hyper-Terminal" type of software tht allows me to interface to H/K ecu via Openport2.0 (anybody ?).
As I am trying out one step at a time, I will start with the following conversation with the ECU ;
>atz ELM327 v1.3 compatible
>at h1 at h1 ; headers are turned on to see which ecu responding
>at h1 OK
>011c 11c
>011c BUS INIT: OK ; ecu only responds to KWP2000 (refer ELM327 reference, set ELM to >AT SP5)
>011c 83 F1 18 C1 6B 8F 47 ; not sure what this refers to as it is the same response for all ECU commands after "BUS INIT : OK". Anybody ?
>011c 11c
>011c 83 F1 18 7F 1 12 1E ; 7F means negative response. Not sure if the other bytes carry more infor.
>011c 83 F1 11 7F 1 11 16 ; F1 refers to the ELM
>0100 100
>0100 86 F1 18 41 0 80 0 0 0 50 ; apparently, only 1 PID is supported (by ECU 18h), not sure where is the rest Anybody ?
>0100 83 F1 11 7F 1 11 16 ; negative response from the other ecu (SRS ? Gbx ?)
>0101 101
>0101 86 F1 18 41 1 0 4 0 0 D5 ; any clue what does it say ??
>0101 83 F1 11 7F 1 11 16
>0902 902
>0902 83 F1 18 7F 9 12 26 ; negative response to vehicle ID request
>0902 83 F1 11 7F 9 11 1E
>03 3
>03 87 F1 18 43 0 0 0 0 0 0 D3 ; Zero trouble codes stored (am I relieved !), but it works for H/K
>03 83 F1 11 7F 3 11 18 ; Negative response from the other ECU
Since this is my first post, sorry for being over enthusiastic. As mentioned before, any sharing that could further advance on diagnostics & flashing the H/K ECU will be most appreciated.
