by MeOH » Tue Feb 17, 2009 3:25 pm
"When the spark plug fires the burn starts after a short delay (kernel growth phase). This burn accelerates and builds more and more heat and therefore pressure in the cylinder. The piston in the meantime is on its way to TDC and then (initially slowly) back down. There is a point in this process where the pressure peaks. Ideally you want that point to be at about 15-20 deg ATDC. The exact location depends on engine geometry like bore/stroke ratio and rod-length/stroke ratio, but is INDEPENDENT of engine load, boost or RPM. With ign advance you move where that ppp occurs. If you achieved at a given condition the correct ppp, the engine produces the most power for the fuel you give it. Advancing more costs power, advancing less also.
The optimal ppp is achieved when you reach MBT (minimum best timing), where more advance does not make more power.
In many engines, you can't reach MBT because the engine starts to knock before you reach it." Allmendinger So I would guess CR wont change ppp but you may need to retard to control knock. If high octane is used you may keep the same ignition and enjoy the HP
