Ok, So I just attempted to switch from the emanage to using ecu flash. I had problems with the emanage not being able to hold a steady Idle.
I will start with my mods:
t25 turbo
forge mbc
walbro 255 fuel pump
560cc injectors
11-12 psi
I got the idle running nice and steady with ecuflash, but I am having alot of issues getting acceleration to work correctly. The stock Injectors are 240cc and the injector scaling doesn't appear to make any difference when I change the value.
When I rev the engine or drive in first or second gear the car surges bad, but my afr stays fairly consistent 10.3-9.8, I know that is really rich but at the same time It appears that I am getting a lot of knock. I attached a quick log, hopefully someone can tell me if something is blatantly wrong.
