Hello Everyone, I am new to openecu and I am instrested in learning how to remap ecu's. I have purchased a galleto cable which I have used to back up my orginal map. I then found a map which claimed to be a performance map and loaded it onto my ecu. However, the car did not start after. So I then Uploaded the orginal map onto the ecu and the car worked correctly.
Details of car is a Renault Clio 172 sirrus 34 Euro 4 ecu
Anyway the help I was after is what software could I use to edit the standard map myself as apposed to using someone elses. or if anyone can help me with the standard map to get me started?
Thanks In Advance
Dean
