Buzz313th wrote:crispyduck wrote:gethin wrote:You only need to close the green connectors to read the ECU.
For EDM MY03 WRX you also have to jumper the flash block.
Phil, Did you get it working?
JB
Didn't have any time to work on it last night.
To verify the drivers installed for the USB Serial Converter are FTDI, 12/12/2005 version 1.0.2176.0 and the USB Serial Port (COM5) is FTDI, 12/12/2005 1.0.2176.0.
Port Settings on COM5 are 9600,8,N,1, No flow control. Is that my problem or does the software go ahead and override with the port settings that XP is setting?
If I get a chance tonight I'm going to try to jump the block to see if that lets me read but I'm not sure I'll get home early enough to have much time to work on this.
