Page 1 of 4
Mitsubishi Evo flashing
PostPosted: Sat Jan 28, 2006 11:20 am
by GTODesign
Hi all,
I've been working on Evo 1-3 (EPROM based) ECU tuning for some time now and have just started work on Evo 4+ when I stumbled upon this fantastic community. From what I've read so far, there is an Evo version in the pipeline but what stage is it at?
PostPosted: Sat Jan 28, 2006 8:50 pm
by cboles
I've written my own SH reflashing kernel and am flashing Evo 7/8 right now. I'm waiting to hear back from a friend regarding success with the Evo 9. I'm trying to source the special connector from Japan to put together a OpenPort cable for people that can easily plug into the Evo and reflash it. The reflashing work is basically done - I'm just working on some other details of the program right now. I have added a lot since the last version of EcuFlash. I'm also debating releasing a full version with the map editing, or just the reflash tool. In some ways the tool is awkward until it is complete.
PostPosted: Sun Jan 29, 2006 12:18 am
by GTODesign
Sounds good. Have you tried it on Evo 5 and 6 yet? I have access to both 5 and 6 if it's any help?
I would suggest Evo 4 as well but the PCB I have looks like a bit of a halfway house between Evo 1-3 and Evo 5/6. The MPu is a 100pin unit that I'm still trying to identify.
PostPosted: Sun Jan 29, 2006 7:05 am
by cboles
What processor is in the Evo 5/6? Can you read the numbers off of the CPU, give me the pin count, and tell me which pins the crystal is connected to (and also the crystal frequency)? Some pictures of the PCB would be useful also.
PostPosted: Sun Jan 29, 2006 8:09 am
by GTODesign
MH7202F Renesas chip on the E5/6.
PostPosted: Sun Jan 29, 2006 8:21 am
by GTODesign
Forgive my ignorance (I'm still learning here :D ) but I assume the crystal is the silver item with the yellow label near the plug?
PostPosted: Sun Jan 29, 2006 10:09 am
by cboles
Looks to be from the H8/500 series. A H8/539F (128k flash), I believe. Different processor core than the newer EVOs which use SH-2. I would have to write a new kernel for this car.
PostPosted: Sun Jan 29, 2006 10:19 am
by cboles
you can see links to these old datasheet here, but they are nowhere on the Renesas site anymore.
http://technsys.com/hitachi/line_up/h8500_lineup.htm
PostPosted: Sun Jan 29, 2006 11:20 am
by GTODesign
I assume the writing of a new kernel is quite an undertaking. Would it be a viable prospect? Would there be anything I can do to help?
PostPosted: Mon Jan 30, 2006 2:10 am
by NeverLies
I'm just looking for some information on a UC like this one : MH7203 so should be close to your UC. If you find more information on this one, let me know, will do the same ;)
PostPosted: Mon Jan 30, 2006 2:50 am
by GTODesign
No worries. What vehicle is the MH7203 from?
PostPosted: Mon Jan 30, 2006 3:48 am
by NeverLies
Not a vehicle ;)
This ECU is in a MY2005 Kawasaki jetski (I think it is common to all Kawasaki). I'm just cleaning all the board right now ... just know the reference and then will need to count for pins and find oscillator.
Colby, let me know if you have any experience or material for this UC ;)
PostPosted: Mon Jan 30, 2006 4:07 am
by GTODesign
Crikey, they've come a long way since I was last dabbling with jetski's.
PostPosted: Mon Jan 30, 2006 4:38 am
by NeverLies
UC is 28 pins by side, as in evo 5/6. Hope that even if reference is not exactly the same, I will find some common parts !!
I'm looking for an ISP connector on this board and still cleaning to find oscillator.
PostPosted: Mon Jan 30, 2006 7:52 am
by NeverLies
Here is what the board looks like right now, no ISP found right now.
