Support for 350Z ECU
Re: Support for 350Z ECU
Postby nosajton » Fri Sep 25, 2015 2:00 am
I can reflash any 2003+ Nissan /Infiniti now (finally!) No I dont use uprev, made my own kernel.
Done years of research and finally got it down. I made a kernel to read / write and can modify every map, disable dtc's and even disable NATS (anti theft) so you can install engine in any other car with no worries.
If you are local to Southern california I offer this as a service bringing the car to me. If you don't live in SoCal, you can mail me ecu and I can flash to your specs and send ecu back. PM me for more info if interested. Works on all SH7055 and SH7058 Nissan ECUS (2003+) This took me many many hours over past couple years but finally got it down.
The system I use cannot be easily made but I can help people if they want to tune their nissans.
nosajton
Postby nosajton » Fri Sep 25, 2015 2:05 am
also can disable / patch to disable Drive By Wire by connecting the input to a 0-5v TPS mounted on the throttle body. Less lag!
nosajton
Postby sub7 » Thu Oct 01, 2015 11:50 pm
Hey nosajton, I'm interested to pull my 03 350z bin out. What is your ecu id?
sub7
Postby nosajton » Sat Oct 31, 2015 2:51 pm
My 350Z is CD003, which is a SH7055 Processor ECU and narrowband front O2's. (512k rom dump)
My G35 is AC306, which is a SH7058 Processor and dual wideband front o2's (1024 rom dump)
Getting closer and closer I can read/write it via KLINE with a 1.3 cable and am working on a kernel to enable CAN flash which should take 30 seconds instead of 2 hours over KLINE.
-J
nosajton
Users browsing this forum: No registered users and 48 guests
