by engr » Wed Dec 28, 2005 6:59 pm
your logs looks like mines with the exception of peak boost and injector duty cycle.. I top out the injector cycle at about 95% , and peak boost of about 16 psi.. but I get pretty nasty boost spikes during shifts.. can you do some logs during shifts? I had a couple of nasty ones after installing SAMCO hose and didn't reset the ECU, it spike upto 19psi once.. but it's all good now..
I also get a lot of -KC at the lower RPM ranges, just like yours..
I am stg 2 4eat as well, with gutted DP and MP.
see my log, my pull from 50km to 170+..
We should compare more notes, since you are the only other 4eat guy I've come across..
- Attachments
- 4eatlog.xls
- (25 KiB) Downloaded 327 times
