cossie1 wrote:Works a treat for me.
Cheers BarryC.
your welcome but I only did the donkey work
merchgod solved the problem
cossie1 wrote:Thanks to merchgod aswell then
Quick Q for you whilst you are here.
As E6 ecu's can now be read, will it be possible to upload them rom into an E7 ecu ?
Or will that fail due to the different processor type ?
BarryC. wrote:cossie1 wrote:Thanks to merchgod aswell then
I dont imagine thats possible but the beauty we now have is we can see the E5,6 rom so it will be possible to set the maps from an E7 rom up to be the same as your stock E6 rom and tune from there,
cossie1 wrote:BarryC. wrote:cossie1 wrote:Thanks to merchgod aswell then
Have you done the wiring mods on your car to run an evo 7 ecu on yours without problems ?
There was a post on the MLR telling me how to get it all working, but wasn't 100% about it, as it involved having the AC and Rad fan wiring connected to the same pins
cossie1 wrote:Chicken![]()
Nah I feel the same about not cutting into the loom, but it's no different really to wiring in an AVCR or similar.
Easy enough to put it all back as it was
Ok next question for you (as me being here is all your fault)
How do I create the XML files ?
BarryC. wrote:no the definition file is only for reading the rom it has nothing to do with flashing, when you flash an ecu you download the whole rom same for uploading,
cossie1 wrote:BarryC. wrote:no the definition file is only for reading the rom it has nothing to do with flashing, when you flash an ecu you download the whole rom same for uploading,
Thats ok then
But you do an some kind of xml to actually open the rom to start with right ?
Oh and I am not sure if the rom or the xml is wrong for the evo 7 EDM Ralliart rom, as the High Octane Map Fuel Map looks very strange compared to all the other Rom's I have looked at.
If the xml was wrong, it wouldn't affect the actual rom when it was flashed in though, that correct ?
BarryC. wrote:send me this xml and the rom ??and no if the definition xml was wrong it wouldnt matter when you flash it??
you only need the xml to read the rom not to upload or download it,
